installing amp wire in a eg hatch
if your talking about the big red one that goes to the battery just find a hole in the fire wall to stick it through and run it under the carpet do the same with the rca's too. its not that hard unless you dont know what your doing in that case take it to a stereo shop.
Probably not covered because it's pretty straight forward. Power wire goes from + on battery, through firewall (just remove a grommet somewhere), under carpet to where your amp is. Make sure you have a fuse on the power wire (usually 6"-1 foot from battery). Do not hook power wire to battery until last. Run rca's from radio to amp. If you don't have aftermarket radio, buy a line out converter. Remote wire goes from the red wire (ignition switched power) on the radio to the remote plug on amp. Ground wire goes to a metal part of the car (make sure to scrape away paint if there is any). Then run speaker wire to subs/speakers.
Understeer
Audio / Security / Video
Jul 29, 2002 06:47 PM
