Install diagram?
Old Mar 30, 2004 | 10:54 PM
CivHatchH22's Avatar
Default Install diagram?
Anybody have a diagram on where everything is hooked up to. including sub, amps, components, etc.
Old Apr 1, 2004 | 01:19 AM
Goatsterrman's Avatar
Default Re: Install diagram? (CivHatchH22)
12volt (power wire)-Usually Red in color-This wire will run from the positive Terminal on the Battery to the 12volt input on the amp. You will need to put either an inline fuse or a circuit breaker as close to the battery as possible. This keeps wire, in case of a short, from catching your car on fire!
Ground Wire-Usually Black in color-This wire will go from the Ground or Negative input on the amp to the closest bare metal you can find. This wire should be attach with a metal screw going through a ring terminal, make sure and scrape the paint off from where ever you are attaching the ground. Also make sure not to screw through any body panels or into the gas tank.
Remote/12 volt Turn On-Usually Blue or Orange-This wire will run from behind the radio connect to either the remote turn on or accesory wire. This wire will be attach to the amp at the Remote/12 volt Turn On imput.
You will also have to run atleast one set of RCA's from behind the radio to the RCA imput on the amp.
The last thing will be that you need to connect the speakers that the amp will be running to the speaker outputs of the amp.
If you list all your equipment I can give you better instructions, Tell me what radio you're using, what kind of speakers(Subs or Highs), what kind of amp(RMS/MAX wattage, Brand, Mono/2/4 channel)
Any other questions just ask.
Old Apr 1, 2004 | 08:29 AM
I'm just wondering how to hook up the components. tweeters and mids.
Old Apr 1, 2004 | 09:01 PM
hybrid racing's Avatar
On the crossover is should have a few diffent places to insert speaker wire, You should have a negative and positive place for the "Imput" Here you will insert the speaker wire coming from the radio or amplifier.
Next you will have a negative and positive spot that should say "Mid" that will be where you will insert the wires that go to the midbass driver
The last set of terminals should say high or tweeter, this is where you will connect the tweeter
Old Apr 1, 2004 | 10:38 PM
Default Re: Install diagram? (6spdEG)
So what about the speaker wire that is already there from the stock mids?
civichatch67
Mar 23, 2005 01:46 PM
OneCamIsEnough
Audio / Security / Video
Aug 27, 2004 09:21 PM
JMX
20
Mar 3, 2004 11:30 AM
ChaosUnbound
Feb 24, 2004 04:20 PM
Understeer
Jul 29, 2002 06:47 PM
