Brake Lights, where did they go!?
The last couple of days I've been working on my car. 93 Civic VX
I've done these things:
Plugs/Wires
Cap/Rotor
Oil Change
Fuel Filter Change
New Carpet
New Gas Tank (other had a hole)
New o2 Sensor
Before I touched the car to do any of this work, the brake lights were fine. 1 Light was out but the rest were a-ok. Now when I fire the car up, the normal lights come on, but no brake lights.. is it possible that all the bulbs just blew so no brakes or could it be a wire or something? I checked the fuses and no luck, so I'm at a loss for things to try. Any help is HIGHLY appreciated.
Modified by Mafiozo at 1:31 AM 3/24/2005
Plugs/Wires
Cap/Rotor
Oil Change
Fuel Filter Change
New Carpet
New o2 Sensor
i've had this problem before.. if you are ABSOLUTLEY POSITIVLY SURE.. it's not your fuse or light bulb..
it is MOST definatly going to be your STOP LAMP SWITCH ASSY. it's located on the back of your pedal.. probably has no relation to your maintanence stuff it probably just pooped out b/c it felt like it.. spray WD40 straight on it.. it should work fine again.. check the contact on that switch maybe the wiring or something came loose.. but your pedal should be coming in contact with that switch.. if not go to your dealer buy a switch or ask them to fax you a picture of what it would look like if you don't own a helms.
good luck*
good luck*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Strawb3rri3 »</TD></TR><TR><TD CLASS="quote">i've had this problem before.. if you are ABSOLUTLEY POSITIVLY SURE.. it's not your fuse or light bulb..
good luck*
that wasnt the issue, we checked.. all is well for the stop lamp switch assembly
good luck*
</TD></TR></TABLE>that wasnt the issue, we checked.. all is well for the stop lamp switch assembly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mafiozo »</TD></TR><TR><TD CLASS="quote">I'll check..
</TD></TR></TABLE> f your horn doesn't work it's the 20 amp fuse in the fuse box under your hood
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 civic VX B18c »</TD></TR><TR><TD CLASS="quote"> f your horn doesn't work it's the 20 amp fuse in the fuse box under your hood</TD></TR></TABLE>
Horn works.
Horn works.
Get out and get an ECU safe* test light, Snap On has a good one, and check the wires in the back. See if they are getting the proper current.
* ECU safe is a relative term. There really is no such thing. =P
turbosir89
19
May 4, 2018 12:17 PM
Blackcat_78
Oct 20, 2007 12:20 PM
here it goes..
