h22 motor swap need help
Old Mar 23, 2005 | 12:45 PM
hondaaccord94's Avatar
Default h22 motor swap need help
alright i put a h22a into 94 accord non-vtec,but the motor is vtec so they installed the computer and theres a plug misssing i think its the v-tec but im not sure so if anyone could help me out what to do?where to go?thanx
Old Mar 23, 2005 | 02:13 PM
scrubachu's Avatar
Default Re: h22 motor swap need help (hondaaccord94)
a plug missing.... you mean into the ecu?? you got major problems then man.... there should be 3 plugs into the ecu if you have obd1..... you also have to add 3 wires... 1 for vtec solenoid, 1 for vtec pressure switch and one for the knock sensor and run those wires through the firewall to to the ecu... there shouldne be any plugs missing...
Old Mar 23, 2005 | 06:45 PM
actually i have four plugs in the ecu i have only connected three wire harnesses the fourth one i dont know what to do because i dont have a wire harness for that one could anyone tell me where to go on that to buy any web sites or how can i do it myself
Old Mar 24, 2005 | 07:17 AM
scrubachu's Avatar
Default Re: (hondaaccord94)
what year is the h22? if the ecu has space for 4 plugs, then it is obd2 and you'll need to find a different harness. if you have 3 plugs on the harness, it would be easier to just get an obd 1 ecu, and use the same harness... are you sure the shop wired the car correctly?
Old Mar 24, 2005 | 08:39 AM
its 96,which ecu is better for my car i used my old wire harness and my car used to be a non vtec so i think the harness thats missing is the vtec because i didnt have it before do you know anyone i can go to so he can check it out.i dont know if the shop wired them correctly i personally dont think so so if u could tell me where to go to fix that ill apreciate it.thanx man
Old Mar 24, 2005 | 08:48 AM
THEROPE's Avatar
if its a 96 you got a obd2 ecu you need to get a conversion harness from like hasport or skunk2
Old Mar 24, 2005 | 08:50 AM
THEROPE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaaccord94 &raquo;</TD></TR><TR><TD CLASS="quote">its 96,which ecu is better for my car i used my old wire harness and my car used to be a non vtec so i think the harness thats missing is the vtec because i didnt have it before do you know anyone i can go to so he can check it out.i dont know if the shop wired them correctly i personally dont think so so if u could tell me where to go to fix that ill apreciate it.thanx man</TD></TR></TABLE>
the harness plug you are missing is not vtec its just more crap that came with the obd2 cars, like said before you only need to wire in 3 wires for vtec
Old Mar 24, 2005 | 09:00 AM
scrubachu's Avatar
Default Re: (THEROPE)
no need for a conversion harness. just get an obd 1 p13 or p28 or gsr ecu. you will still have to add the 3 wires i mentioned earlier. i will have my p13 jdm prelude ecu for sale in a bout a week when i get my p28 if you are still interested by then.
Old Mar 24, 2005 | 12:39 PM
st95accord's Avatar
Default Re: (scrubachu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scrubachu &raquo;</TD></TR><TR><TD CLASS="quote">no need for a conversion harness. just get an obd 1 p13 or p28 or gsr ecu. you will still have to add the 3 wires i mentioned earlier. i will have my p13 jdm prelude ecu for sale in a bout a week when i get my p28 if you are still interested by then. </TD></TR></TABLE>
How can you use a obd 1 ecu on an obd 2 motor??? I'm gonna be doing this conversion in then next couple months and this interests me since the 96+ H22's were supposedly built better than the older versions.
~A
Old Mar 24, 2005 | 12:45 PM
scrubachu's Avatar
Default Re: (st95accord)
im using one now. i just swapped in a new 01 sh h22 to replace my old 95 jdm h22, and im still running the same p13 ecu. runs fine, cept we yanked out the emissions stuff, so i have the egr code, which is why im gettin a p28. im still usin me original accord harness on my 4th gen
zaida08bk
Mar 30, 2015 02:30 AM
luvmihatch
Oct 5, 2008 10:34 AM
dbodizzle
Sep 30, 2008 03:32 PM
omarisramo
Aug 5, 2008 01:45 PM
3litre190
Jul 24, 2007 02:49 PM
