lsd
ok so the tranny is outside the car?
If yes, look through the hole and if you see a pin across, then you don't have LSD, but if you can see straight through the hole without anything interfering, then you have LSD.
If the tranny is in the car, then lift the front so that both front wheels are off the ground. Then turn one wheel and see how the other wheel turns. For example, if you have LSD and you turn the right front tire towards the front then the left front tire should spin towards the front as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACC0RD22 »</TD></TR><TR><TD CLASS="quote">if you bought it from japan . . . no US accord came with an lsd</TD></TR></TABLE>
He would most likely buy a used transmission, right? Then why couldn't he buy a used US transmission with a aftermarket LSD?
1hotvtec
76
Oct 11, 2003 04:37 PM
