Custom CP Pistons 87.5mm
Old Mar 23, 2005 | 11:29 AM
edo's Avatar
edo
Default Custom CP Pistons 87.5mm
These three sets are the newest X-style forging from CP Piston. We originally purchased their shelf SC7147x for the K24 (12.5:1) in 87mm only to find out that the intake valve relief wasn't sufficient to run our most aggressive cam at full 50 degrees VTC advance. So, we had these made with an additional 0.065" intake valve relief. Plus, we changed up the ring package to run a 2.0mm oil ring instead of the shelf piston 2.8mm oil ring. The static compression of these are 12.2:1 in a K24 and ~11.1:1 in K20A(2) configuration. We decided not to bring the dome cc up to compensate for the deeper intake valve relief since pump gas works well on 12:1 for K-series street motors. These CP pistons feature the only dome that extends furthest to the edge. So far, the rest are very conservative and have a greater margin, thereby giving up material which could have been used for more compression.
These pistons are intended for K24 blocks that do not wish to sleeve, but should overbore 0.5mm to get the cylinders round. They can also be used in 2.0L blocks, but you should check out cylinder wall thickness of your block as it may be too thin at 87.5mm on the K20A(2).
3 sets of Cunninghams in K20A(2) length and 3 sets of Pauter K24 length are in production to go with these guys for more testing.
-Ron
Old Mar 23, 2005 | 11:32 AM
Real_E-AT's Avatar
Default Re: Custom CP Pistons 87.5mm (edo)
The K series future looks very promising!
Old Mar 23, 2005 | 07:48 PM
justBLZE's Avatar
Chopper 2 Hopper
You guys doing some serious engine building.
Keep it up
Old Mar 23, 2005 | 07:53 PM
Dan GSR's Avatar
Default Re: Custom CP Pistons 87.5mm (tommy69)
Ron = K series *****
Old Mar 23, 2005 | 08:18 PM
edo's Avatar
edo
Default Re: Custom CP Pistons 87.5mm (Dan GSR)
guilty as charged....
My name is Ron and I'm a K-series addict....
Placed another custom order today too... 90mm version of this with a little twist. They'll be mated to the Cunningham Ti rods and an 88mm crank.
-Ron
Old Mar 23, 2005 | 09:45 PM
Eddiebx's Avatar
what V12 honda motor is that going in?!
Old Mar 30, 2005 | 06:00 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Nice stuff Ron.
96halx
Jul 25, 2009 11:09 AM
eg:R
Mar 4, 2007 03:35 PM
darkdayz
Oct 11, 2005 11:04 AM
egvtec
Nov 30, 2004 11:13 AM
LudeyKrus
Jun 30, 2003 08:26 AM
