alternator belt too long?
Old Mar 23, 2005 | 11:16 AM
sparxx's Avatar
Default alternator belt too long?
ok..I've got a 91 crx with a b16a1 swap in it..I just replaced the alternator with one from an 91 ls.now the belt is too long...what car should the belt I need come off of...thanks
Old Mar 23, 2005 | 11:27 AM
manson's Avatar
Default Re: alternator belt too long? (sparxx)
go to Pepboys, Napa, Autozone and buy a few belts in different sizes. buy ones that are smaller than the one you have now. try fitting some on untill you find the one that fits. then take back the ones that don't fit.
unless someone here actually knows which one you need.
but thats what i did when i needed a belt. don't know which vehicle it was for, but it works.
Old Mar 23, 2005 | 11:32 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
NAPA # 25-040300 is the shortest I could find that would work..
If that is not long enough try 25-040310..
Old Mar 23, 2005 | 12:31 PM
ajcrx's Avatar
Just get one from a 2000 si or a 94-95 DOHC del sol and you will be fine.
Old Mar 23, 2005 | 01:45 PM
RCautoworks's Avatar
Default Re: alternator belt too long? (ajcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ajcrx &raquo;</TD></TR><TR><TD CLASS="quote">Just get one from a 2000 si or a 94-95 DOHC del sol and you will be fine.</TD></TR></TABLE>
Just be careful though, a lot of places will have the del sol listed but have it listed as the sohc one.
Old Mar 23, 2005 | 03:23 PM
sparxx's Avatar
Default Re: alternator belt too long? (90blackcrx)
si model right?not the vtec.
Old Mar 23, 2005 | 04:15 PM
Slow ass EF's Avatar
the si is the vtec model and if u have a b16 u need the belt for a b16
Old Mar 23, 2005 | 06:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sparxx &raquo;</TD></TR><TR><TD CLASS="quote">si model right?not the vtec.</TD></TR></TABLE>
As the guy above me stated, the si model has vtec. If your talking about the del sol, you need the belt for a 1.6 dohc vtec del sol engine
Old Mar 23, 2005 | 06:23 PM
eda6's Avatar
Wrap a piece of string around the crank and alternator pullies to find belt length.
Pull the alternator forward and get a measerement, push the alternator back and get another measurement. Multiply inches by 25 to convert to millimeters. Now you will know min/max belt sizes. Your going to need a 4pk??? belt.
Old Mar 23, 2005 | 06:46 PM
crxbust's Avatar
you could try a 2000 civic SI b16a2 or a 95 del sol B16a3 thats what i did....
Old Mar 23, 2005 | 07:58 PM
Burlyirishdude's Avatar
Default Re: alternator belt too long? (crxbust)
i got the belt for a 94 del sol vtec......and then asked for the next size down....i think it's a 1/4"smaller then that. Kelly Springfield is the co. Good belt...the teeth are strong.. and none of that rediculous, "you have to bang in the chais for the alt to fit"
flatblack-h22
Aug 17, 2006 05:53 PM
jrzy2nR
Jan 20, 2006 05:25 PM
iNTEGRA-vibe
Jul 29, 2004 10:44 AM
andrewasf77
Jul 10, 2003 08:24 PM
HondaDriver85
May 7, 2003 12:08 PM
