weld magnums scuffing brakes?
Old Mar 23, 2005 | 10:16 AM
alteredautosports's Avatar
Default weld magnums scuffing brakes?
Has anyone had an issue with magnums scuffiing the wheels lightly on the calipers when you spin them? I am talking lightly is there another brake that should be used or do you mill the caliper face to clear?
Old Mar 23, 2005 | 10:49 AM
Group Tenacity's Avatar
Default Re: weld magnums scuffing brakes? (alteredautosports)
I had this problem, but it wasnt just scuffing them, it was definately hitting the callipers... At the time i took a grinder to the callipers to shave off some material, but i didnt want to go too far and wasnt able to make them clear, so i got a set of 1/4" wheel addapters and i dont have a problem any more...
Mike...
Old Mar 23, 2005 | 12:24 PM
R THIS's Avatar
Default Re: weld magnums scuffing brakes? (Group Tenacity)
they fit on eg brakes... but if your running integra front callipers, they will rub a bit..
i run 1/4 inch spacers and they work well.. just dont forget to bring the spacers to the track with you!!!
Old Mar 23, 2005 | 03:49 PM
Default Re: weld magnums scuffing brakes? (R THIS)
I would think spacers would be bad at 150mph+ anyone else on this?
Old Mar 23, 2005 | 04:00 PM
EVIL TYPE R's Avatar
I had the same problem...i grinded the back of the bolts the were hitting the caliper and used the smallest spacer I could find... I have ITR brakes up front.
Old Mar 23, 2005 | 04:06 PM
whatVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R THIS &raquo;</TD></TR><TR><TD CLASS="quote">they fit on eg brakes... but if your running integra front callipers, they will rub a bit..
i run 1/4 inch spacers and they work well.. just dont forget to bring the spacers to the track with you!!!</TD></TR></TABLE>
so this isn't a problem on stock EG brakes? I have a set but haven't used them yet.
Old Mar 23, 2005 | 04:15 PM
boostedh22a's Avatar
just run eg brakes. they will clear with no issue
Old Mar 23, 2005 | 06:02 PM
4piston's Avatar
Default Re: weld magnums scuffing brakes? (boostedh22a)
They rubbed our EG brakes so we just took a grinder to them.
Old Mar 23, 2005 | 06:06 PM
Default Re: weld magnums scuffing brakes? (4piston)
thats weird, I didn't have to grind on mine at all for the wheels to clear. And I think this is the guy that ended up with my old race car????
Old Mar 23, 2005 | 06:10 PM
whatVTEC's Avatar
so what is it, do I need to grind the calipers or not?
Old Mar 24, 2005 | 12:42 AM
well I had 15" wheels and they cleared with no grinding. I believe that 4piston had 13" wheels on his EG
Old Mar 24, 2005 | 06:47 AM
whatVTEC's Avatar
Default Re: (boostedh22a)
well my fronts are 13's, so am I going to have to grind the brakes?
Old Mar 24, 2005 | 07:25 AM
4piston's Avatar
Yep that was the difference. I forgot you had bigger wheels.
Just grind them until they fit. Its no big deal its like a 10 minute job.
Old Mar 24, 2005 | 08:02 AM
Default Re: (4piston)
Yep carey I have your old car just picked up some slicks from joe and mounted them on the car the just barely scuff it doesn't affect the turning of the wheel at all it is just minorly touching. Been working on it alot just ordered a rear axle from the guy that built joe's. I look forward to meeting you some weekend at joe's place, It only takes 3 hrs to get there from when I am. I'll start listing pics soon for you.
Old Mar 24, 2005 | 11:58 AM
whatVTEC's Avatar
I'd rather just get some spacers, how thick of one should I get?
Old Mar 24, 2005 | 01:48 PM
Default Re: (whatVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whatVTEC &raquo;</TD></TR><TR><TD CLASS="quote">I'd rather just get some spacers, how thick of one should I get?</TD></TR></TABLE>
you dont want spacers on a race car. just grind away, no big deal
"Yep carey I have your old car just picked up some slicks from joe and mounted them on the car the just barely scuff it doesn't affect the turning of the wheel at all it is just minorly touching. Been working on it alot just ordered a rear axle from the guy that built joe's. I look forward to meeting you some weekend at joe's place, It only takes 3 hrs to get there from when I am. I'll start listing pics soon for you."
Hows the car coming along. I wouldn't mind seeing some pics if you have any. I definately miss her. my email is cbales@insightbb.com if you have any pics.
take care
Old Mar 24, 2005 | 07:22 PM
therealpoorboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4piston &raquo;</TD></TR><TR><TD CLASS="quote">Yep that was the difference. I forgot you had bigger wheels.
Just grind them until they fit. Its no big deal its like a 10 minute job. </TD></TR></TABLE>
no both the 13 and 15" wheels use the same center section.
Old Mar 25, 2005 | 06:31 AM
whatVTEC's Avatar
this may be a dumb question, but why don't you want spacers? I used to have spacers on my bogarts
Old Mar 25, 2005 | 03:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whatVTEC &raquo;</TD></TR><TR><TD CLASS="quote">this may be a dumb question, but why don't you want spacers? I used to have spacers on my bogarts</TD></TR></TABLE>
just a personal preference
Old Mar 25, 2005 | 04:10 PM
XXXRacing's Avatar
I run spacers on my crx at 150+ MPH. Work fine. Brian
lindseyhunt1090
Mar 9, 2016 02:16 PM
SlowB16
Sep 7, 2013 12:41 PM
d16efsedan
Mar 27, 2007 05:57 PM
denieone
Jun 24, 2002 02:17 PM
Kamin
57
Mar 20, 2002 10:55 AM
