B17A Miss Firing
Old Mar 23, 2005 | 09:29 AM
tequilakid's Avatar
Default B17A Miss Firing
I need help..
under light accelleration, and between 1500-2000 rpm, the engine will miss fire quite badly. I pulled the codes the ecu was throwing and there was 22 (VTEC pressure switch) and 41 (Primary O2 sensor heater), now i dont think that these have any thing to do with the miss firing, but they could.
Any help is greatly appreciated
Old Mar 23, 2005 | 09:43 AM
Jasper_db1's Avatar
Default Re: B17A Miss Firing (tequilakid)
How does it run above and below that RPM?
How does it run at WOT?
When was the last time you did a tune-up?
Old Mar 23, 2005 | 09:44 AM
rastropovitch
Guest
Posts: n/a
Default Re: B17A Miss Firing (Jasper_db1)
perhaps switching out the wires and plugs to rule that out before moving to the O2/cat
russellgold234
Apr 5, 2015 01:17 PM
blackcivic11
Aug 28, 2008 10:29 AM
'96typeR
May 12, 2008 12:16 PM
dkrangers
29
Mar 25, 2005 12:46 PM
c_buz
Jan 13, 2005 06:15 PM
