header rattle
Old Mar 23, 2005 | 08:26 AM
00CivicSleeper's Avatar
Default header rattle
just installed a dc sports 4-1 header on my 2000 civic ex, now i get a REALLY BAD rattle. has anyone experienced this and does anyone know how to fix it? it seems like where the 4 tubes come together, underneath the transmission i believe, its kinda close could that be it?
Old Mar 23, 2005 | 08:32 AM
WestEM1's Avatar
Default Re: header rattle (00CivicSleeper)
Is ur compression springs on the two bolts connected to the catalytic converter on right? and did you tighten up the two bolts on the hanger underneath the car near the o2 sensor?
Old Mar 23, 2005 | 08:34 AM
balistik's Avatar
someone forget the gasket?
Old Mar 23, 2005 | 08:36 AM
gasket between the cat and header? i didnt get one... westem1: yes i did
Old Mar 23, 2005 | 08:40 AM
WestEM1's Avatar
Default Re: (00CivicSleeper)
You don't need to switch out the donut gasket between the cat and the header....it should be fine...other than that..i dunno...
Old Mar 23, 2005 | 09:12 AM
i didnt put in a donut gasket. the dc header had sort of a mesh/wire around the tip, but it looked all worn out. i bought it used. is that the gasket? do i need a new one? could the header be hitting the bottom of my transmission?
Old Mar 23, 2005 | 10:09 AM
eg4usdm's Avatar
well i dont have an ek but i just installed a new header on my eg and i forgot on my stock header where the downpipe meets the cat there is a little ring that sits on the end of the header and when you insert/bolt it up to the cat it acts a space filler so you dont have exhaust leaks.
when i first did it i forgot it becuase it looks like its actually part of the stock header so when i installed it there was an exhaust leak and since there was a gap where the header inserts into the cat it rattled.
so look on your stock header and see if there is a little ring around it that you can remove but dont be rough with it because it is made of some softer metal stuff.
that is my guess i hope it helps sorry man!!
Old Mar 23, 2005 | 07:40 PM
i checked and it has the gasket on it....
Old Mar 24, 2005 | 05:07 AM
WestEM1's Avatar
is there a space between the header and the cat? i kno its an obvious question..but maybe u can tightened the bolts alittle bit more and compress those springs tighter
Old Mar 24, 2005 | 05:27 AM
there isnt
Old Mar 24, 2005 | 02:46 PM
eg4usdm's Avatar
sorry bro i dont know what it is then
and its not really a gasket its more of a ring that fills inspace. i searched and couldnt find a picture of it sorry man!
good luck
Old Mar 24, 2005 | 04:02 PM
GUNNER666's Avatar
Default Re: (eg4usdm)
double check every bolt is tight
thats about all i can think of.
saleen288
Sep 19, 2006 04:15 PM
hakkoo
Feb 24, 2006 10:42 AM
Wazup
Sep 7, 2005 01:08 PM
Red_Si
20
Dec 16, 2004 08:13 AM
