Running OBD1 GSR ecu for an OBD2 ITR motor!!! help!
Sup guys, i already did a search and couldnt really find what i wanted....
basically, i went ahead and bit the bullet and bought a legit salvaged ITR motor with low miles and i'm swapping the longblock into my GSR...
i will be using an OBD1 gsr ecu, wiring harness, injectors, and distributor to plug into the OBD2 B18c5
all i want to know is: will i run into any problems being that the b18c5 has a different fuel map than the OEM gsr motor? i know hypothetically i will be "safe" because they all use OEM 240cc saturated injectors, and the rev limiter will be lower on the gsr, but can anybody see any long-term bad effects on my new motor?
thanks in advance, any help will be appreciated!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo »</TD></TR><TR><TD CLASS="quote">Try the hybrid forum.</TD></TR></TABLE>
And why didn't you just buy the ITR ECU along with the motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonFedHatch »</TD></TR><TR><TD CLASS="quote">all i want to know is: will i run into any problems being that the b18c5 has a different fuel map than the OEM gsr motor? i know hypothetically i will be "safe" because they all use OEM 240cc saturated injectors, and the rev limiter will be lower on the gsr, but can anybody see any long-term bad effects on my new motor? </TD></TR></TABLE>
Yeah you're in the wrong forum.
You've got it backwards though, you've got a motor that has higher compression and needs more fuel, and you're throwing on a GSR ECU that's made for a lower compression. Timing and fuel won't be the same.
All in all, though, I would guess the GSR's ECU is conservative enough to not cause any problems...
Get a new ECU or run Hondata/Uberdata and tune it. You're throwing away power by using the GSR one.
I do have first hand experience on this one!
I let me buddy use my ecu to see how it would run in his crvtec (before we got hondata) and I was using his gsr ecu...
talk about SLOW
I didnt get any detonation or hesitation, but it was just alot slower
talk about SLOW
ok well thanks for the input, and i figured the ITR guru's would have SOME knowledge as far as fuel mapping/base on the OEM motors...that's why i posted here, but thanks for shoo-ing me off just because i asked a valid question in a busy forum...
i do plan on keeping the conservative tune of the OEM GSR ecu UNTIL i get the cash to run Hondata s100/200...
anyways, i will be running this ecu for about 1-2 months max, and i'm not hot-rodding the motor any time soon either, but thanks again for the input Chris F and dnatrance
so simple
Feb 9, 2006 10:28 AM
