ls swap idleing
Old Mar 23, 2005 | 06:05 AM
B18del-turbo's Avatar
Default ls swap idleing
i have a 94 del sol with a b18a, i took the engine back out to put a stage 3 clutch in when i put the engine back in it idles at 3,000 and drops back to 1,000 ect ect. switch some vac lines when the engine was out but i try moveing them around and nothing, if some one knows whats wrong or if some one has vac diagrames help
Old Mar 23, 2005 | 06:23 AM
DizzleSizzle's Avatar
Default Re: ls swap idleing (B18del-turbo)
could be your IAC valve. Maybe you damaged it while taking out the motor and putting it back in.
vinnnocc
Jan 17, 2013 08:09 AM
phantom_sol
May 21, 2002 01:03 PM
Farrell
Mar 12, 2002 01:45 PM
