MAP sensor reporting boost when engine is off, & at WOT ?
Old Jan 25, 2002 | 06:14 AM
Greyout's Avatar
Default MAP sensor reporting boost when engine is off, & at WOT ?
my V-AFC says that my MAP sensor is reporting +0.08 when the car is at WOT, or when the ignition is off and the car is on.... is this normal?! I didn't think a MAP sensor could report boost, even if it was malfunctioning.
Old Jan 25, 2002 | 06:57 AM
davew's Avatar
Default Re: MAP sensor reporting boost when engine is off, & at WOT ? (JDM LUDE)
check the settings on your VAFC in the setup section. its not normal.
Old Jan 25, 2002 | 09:08 AM
EE_Chris's Avatar
Default Re: MAP sensor reporting boost when engine is off, & at WOT ? (davew)
At idle, the MAP should read about .95V and at WOT it should be 2.8V (and it should also read 2.8V when the car is not running, but key is on). Typically if the ECU sees something above this voltage, it will set a CEL. The fact that your AFC is reporting a MAP voltage of .08V sounds like its disconnected, not reporting boost.
EDIT: Just having re-read, I assumed that .08 was a voltage reading. And also, the MAP can read boost, it will put out a voltage corresponding to the reading (but only so high in boost)...its the ECU that doesn't want to see boost.
[Modified by EE_Chris, 6:11 PM 1/25/2002]
blkdoutteg
Aug 30, 2012 05:55 PM
H-allmotorda9
Feb 7, 2010 07:29 PM
rdssk8rcs1
Oct 10, 2006 06:43 AM
See Are X
Oct 13, 2005 04:10 PM
silverbulletgsr
May 20, 2004 08:24 AM
