Speed sensor location
It is located on top of the transmission, so that if you take off your air intake hose that leads to your air box, and look straight down through your engine bay from the passenger side of your car, you will see a plug going into the top of the transmission. If you loosen that bolt and pull up, you will be taking your VSS out of the tranny. You can use that hole to fill tranny fluid if you like.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 »</TD></TR><TR><TD CLASS="quote">it's the only thing plugged into the top of the tranny...can't be that difficult.</TD></TR></TABLE>
actually it is twards the rear of the tranny the top has reverse light switch but look twards the rear right below the throttle body
Mora
Sep 29, 2003 06:58 PM
