Speed sensor location
Old Mar 22, 2005 | 08:22 PM
85mm LS VTEC's Avatar
Default Speed sensor location
I have a 92 YS1 transmission, and was wondering where the speed sensor is located. Thanks.
Modified by 85mm LS VTEC at 11:07 PM 3/22/2005
Old Mar 22, 2005 | 10:07 PM
Default Re: Speed sensor location (85mm LS VTEC)
Old Mar 23, 2005 | 02:06 PM
Simple answer. Someone knows.
Old Mar 23, 2005 | 02:47 PM
LSvtec03's Avatar
it's the only thing plugged into the top of the tranny...can't be that difficult.
Old Mar 23, 2005 | 02:48 PM
purplegsr's Avatar
It is located on top of the transmission, so that if you take off your air intake hose that leads to your air box, and look straight down through your engine bay from the passenger side of your car, you will see a plug going into the top of the transmission. If you loosen that bolt and pull up, you will be taking your VSS out of the tranny. You can use that hole to fill tranny fluid if you like.
Old Mar 23, 2005 | 02:49 PM
Stripped Honda's Avatar
99-0104
Default Re: Speed sensor location (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">it's the only thing plugged into the top of the tranny...can't be that difficult.</TD></TR></TABLE>
actually it is twards the rear of the tranny the top has reverse light switch but look twards the rear right below the throttle body
P12 EG6
13
Oct 17, 2007 03:06 PM
MOST
Mar 1, 2007 10:24 AM
iTzKeviN
Aug 12, 2005 01:10 PM
Utilitarian
Feb 14, 2005 01:04 PM
Mora
Sep 29, 2003 06:58 PM
