CV joints/axles shot???
Old Mar 22, 2005 | 04:31 PM
DelSolDon's Avatar
Default CV joints/axles shot???
Ok, pretty sure that at least one of my CV joints took a **** when I was doing some "spirited" driving the other night. When I let off the gas and let my car coast, it started clunking and shuddering at the same speed as the wheels, not the motor, so i suspect the cv joint(s), right? The noise and shudder would lessen a lot and almost stop if I was giving it gas or braking. The noise happens whether I am going straight or turning. I pulled over and jacked up the driver side to check and see if I could visually see anything, but couldn't. I then moved the wheel up and down, all seemed normal, then rotated it forward and then back. It made a loud clunk when I did this and felt out of whack. I have lifetime warranty axles thru autozone so it is not a money issue to change them, just a time issue which is why I would like to get more opinions.
Old Mar 22, 2005 | 05:19 PM
DelSolDon's Avatar
Default Re: CV joints/axles shot??? (DelSolDon)
opinions before I tear my front suspension apart <U>again</U>?
Old Mar 22, 2005 | 05:20 PM
RaYnE's Avatar
sounds like the joint to me, take the wheel off and inspect it again..
might see soemthing a bit better..
maybe its messed on the inside but the boot isnt ripped.
Old Mar 22, 2005 | 05:31 PM
pdiggitydogg's Avatar
Kinda sounds like that to me too.
It doesnt take long to replace an axle...I can do one in about 30minutes (no air tools)
Old Mar 22, 2005 | 06:20 PM
red91sit's Avatar
Default Re: (pdiggitydogg)
Hmm My CV joints click under acceleration while turning, that's usually what cv's do when they go bad.
Old Mar 23, 2005 | 10:19 AM
DelSolDon's Avatar
Default Re: (red91sit)
TTT
Old Mar 24, 2005 | 01:57 PM
DelSolDon's Avatar
Default Re: (DelSolDon)
TTT
Old Mar 24, 2005 | 03:32 PM
B16aDasher's Avatar
when my cv joint when bad, i could only tell when i was turning.
Old Mar 25, 2005 | 05:40 PM
DelSolDon's Avatar
Default Re: (B16aDasher)
um, yea...my f*ckin lug nuts were loose. go ahead, get the little hammer head guy out.
Fiercesomest
Transmission & Drivetrain
Aug 31, 2018 04:12 AM
.Grimace
Sep 11, 2005 05:08 PM
EJ2-Fluffy
Jul 19, 2005 09:05 AM
lowRIDAH
12
Dec 27, 2004 09:05 AM
