Check Engine
Old Mar 22, 2005 | 03:32 PM
SHG_James's Avatar
Default Check Engine
deleted. starting off fresh
08/01/08
Modified by jamescardenas07 at 1:00 PM 8/1/2008
Old Mar 22, 2005 | 03:33 PM
Kyles ej1's Avatar
Default Re: Check Engine (jamescardenas07)
y dont u check for codes and then see whats up
Old Mar 22, 2005 | 03:34 PM
pdiggitydogg's Avatar
Do NOT just reset the damn ecu without pulling the code
Check the code:
http://www.hstuners.com/forums...23007
Fix whatever is wrong...THEN reset the ecu....
Old Mar 22, 2005 | 03:38 PM
Kyles ej1's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Do NOT just reset the damn ecu without pulling the code
Check the code:
Fix whatever is wrong...THEN reset the ecu....</TD></TR></TABLE>i was
talking about this, try this it could be something little and you might end up paying big bucks for something small
Old Mar 22, 2005 | 04:30 PM
well.....yeah the cel comes back on after you reset it because you didnt fix anything!
check the code, fix it, reset...it will not come back if you fix the ****.
Yes it could be from the intake if you fucked something up. It could also be ANYTHING.
<FONT SIZE="5">check the code</FONT>
Old Mar 22, 2005 | 04:46 PM
what difference does it make?
You have a cel and it needs fixing
Lscivic1999
Jan 24, 2007 12:22 PM
sIK.CiViK.EF
May 11, 2006 09:53 AM
mprelude
Apr 18, 2005 05:32 PM
iwhichisme
Apr 1, 2004 05:41 AM
DiSbaDbOi
15
Dec 12, 2003 09:44 AM
