weather stripping targa help leaks
Old Mar 22, 2005 | 12:07 PM
idriveadelsol7's Avatar
Default weather stripping targa help leaks
the driver side of my targa top has a piece of weather stripping (black rubber) that was tore off. should 84$ at the dealership for that piece. can i just go to autozone or pepboys and get like some sort of rubber weather siliccon to patch it up?
Old Mar 22, 2005 | 12:18 PM
IHateJDM's Avatar
Default Re: weather stripping targa help leaks (unrefined7)
tore off? Weird. Search for how people stop their del sols from leaking, and you'll find your answer. Off the top of my head, I think you have to go factory. If so, http://www.hondaautomotiveparts.com
Old Mar 22, 2005 | 12:23 PM
skip.two's Avatar
if you plan on getting new seals, get the 95-97 seals. they were recalled in 94, and supposivedly fixed in 95.
i'd replace a torn seal, but you can keep it if you want. just silicone/lube your seals.
Old Mar 22, 2005 | 05:17 PM
Default Re: weather stripping targa help leaks (jL iLLuZiOnz 9)
my mistake... it's the front winshield portion of the car. yes, it's kinda thinner than the otherside causing it to leak. it's like 100$ for that part.
Old Mar 22, 2005 | 05:30 PM
i cannot find it on http://www.hondaautomotiveparts.com
Old Mar 22, 2005 | 05:56 PM
Plastic_Fork's Avatar
You're going to have to get the seals from Honda or a place that sells OEM Honda parts. There's no aftermarket equivalent for the targa and roof seals for the Del Sol.
I concur with jL iLLuZiOnz 9. The '95+ seals were redesigned due to the leaking issues the '93-'94 seals had. The newer seals are direct fit.
The94delslow
19
Dec 30, 2018 03:43 AM
Wakes4Fun
11
Mar 23, 2009 06:23 PM
Del Sol on Steroids
Nov 9, 2006 07:16 PM
Ragecloak
Mar 5, 2005 09:02 PM
nocturnaldragon
Feb 14, 2005 07:25 PM
