my eg problem
my honda eg is makeing really bad noises like a spulltering noise and a really bad buzzing noise when i gas it.. when i clutch and gas it the shiftlinkage is pulled and moves my motor is moving to when it revs more then usual
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
Sounds to me like you have a bad motor mount... or two. You really need to try and be a little more descriptive. Pop the hood and have someone rev the car and check the movement of the engine assembly. Also go around and check your mounts for torn or missing bushings. Do you have a swap? check your shift linkage bushings and also make sure it hasn't somehow come loose.
Good Luck!
EDIT: What he said
Good Luck!
EDIT: What he said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepingHonda »</TD></TR><TR><TD CLASS="quote">anyone in the irving texas area wanna help me work on it? i would appreaated it</TD></TR></TABLE>
save yourself the time and more headache in the future have two different honda specialist mechanic look at the car. dont nickel and dime problems because they will not go away.
extensioncordy
Nov 22, 2006 12:23 PM
iNERtIA
May 31, 2006 06:42 PM
