Camshafts: Blox vs. Buddy Club
Old Mar 21, 2005 | 08:55 PM
itr1244's Avatar
Default CAM poll :Blox VS buddyclub
i just wanted some input on these cams.
motor will be stock motor 01 B18C5 with 90K Km's on..
planning to get valve train upgrades
AN-R header, 2.5" ehx. intake. vafc.
thanks
Old Mar 21, 2005 | 09:02 PM
acuracy r's Avatar
Default Re: CAM poll :Blox VS buddyclub (itr1244)
i liked my bc spec 3+'s, heard the IV's are supposed to be even better The 3+'s start to drop off before 9, so if your going to be revving past that which i think you are, the IV's would do u much better.
Old Mar 21, 2005 | 09:22 PM
itr1244's Avatar
Default Re: CAM poll :Blox VS buddyclub (acuracy r)
i heard good things about stage 4's but do u think it's too harsh for stock bottom end?
Old Mar 22, 2005 | 01:07 AM
.water's Avatar
i heard so many good things about BC3 cams ..i vote for 4 cause its newer
Old Mar 22, 2005 | 09:07 AM
Big Phat R's Avatar
Are BC4s made by Bigfoot?
Cause like the hairy beast - they are talked about - but never seen in person
They aren't even listed on the Buddy Club USA website
Are Blox made by Lego?
Never heard of them.
I'd stick to the tried and tested manufacturers that back up their product.
Old Mar 22, 2005 | 10:12 AM
Jowee's Avatar
Default Re: CAM poll :Blox VS buddyclub (Big Phat R)
Blox B's eat up the BC 3+ after VTEC. I wouldn't go with the BC IV with that setup.
Old Mar 22, 2005 | 10:14 AM
igyloo's Avatar
Default Re: CAM poll :Blox VS buddyclub (ITR 98 1162)
mods on the motor?
Old Mar 22, 2005 | 10:21 AM
Jowee's Avatar
Default Re: CAM poll :Blox VS buddyclub (igyloo)
J's Racing Intake
Port Throttle Body
AEBS Intake Manifold Port matched to head
Hondata IM Gasket
B&M Fuel Pressure Regulator and Gauge
OBD2 Prelude Injectors
Walbro Fuel Pump
Hondata s200
Vision SS 4-1 Header with 2.5" collector
Test Pipe
Comptech Exhaust
Blox Spec B Cams
OMNI Power Springs and Retainers
Omni Power High Compression Valves
Head Milled 0.02
Buddy Club Cam Gears
Removed Power Steering
Stock bottom end
ITRacer121's R.
Old Mar 22, 2005 | 10:56 AM
acuracy r's Avatar
arent the blox b's more of a stage 2 cam? if so, those numbers would be expected over a stage 1 cam...
Old Mar 22, 2005 | 12:14 PM
RedR's Avatar
they recommend more compression for spec IV
Old Mar 22, 2005 | 12:49 PM
white rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">
I'd stick to the tried and tested manufacturers that back up their product.</TD></TR></TABLE>
That's funny. I don't run cams but I'm partial to S2 S2's or Toda B's.
Old Mar 22, 2005 | 02:11 PM
dnatrance's Avatar
yeah I agree with ITR 98. The spec 4 cams will be wayyy to big. They are better suited for a high compression/stroker setup. I just ordered my spec 3 cams from Password JDM a week ago (on backorder), but searching around on HT, they seem to be the best bang for the buck and I have seen a few people say that the BC4 do put out more peak power, but on a stock type r (or similar setup) they loose to much hp and tourqe across the board.
Old Mar 22, 2005 | 02:34 PM
emotionisdead's Avatar
Very Emergency!!
i just put some buddy club spec 4's in my high comp b20. the cam profiles are ****** awesome. i haven't started it yet, not quite ready. i would go with the buddy club cams
Old Mar 22, 2005 | 07:28 PM
itr1244's Avatar
Default Re: CAM poll :Blox VS buddyclub (EmotionIsDead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">Are Blox made by Lego?
Blox = wicked cams
BC Spec IV
Cam lift: IN 12.3mm EX 11.8mm
Duration: IN 306 EX 302
IN 37 BTDC (1mm OPEN) 52 ABDC (1mm OPEN)
EX 62 BBDC (1mm OPEN) 32 ATDC (1mm OPEN)
V/C IN .007 EX .008
" Dyno is Omnimans 1.9l GSR street motor.
So if that is true, here are the dynos of the various Buddy Club cams"
spec3
all this next info is off http://www.allmotorhonda.com
Manufacturer, Intake, Exaust
EF-1 m24 cams 12.1 mm, duration - 258 @1mm 12.1 mm, duration - 258 @1mm
Toda Spec A 11.6 mm, duration - 250 @ 1mm 11.2mm, duration - 240 @ 1mm
Toda Spec B 12 mm,duration - 255 @ 1mm 12 mm, duration - 245 @ 1mm
Toda Spec C 12.5 mm,duration - 255 @ 1mm 12.5 mm, duration - 255 @ 1mm
Jun Type 1 10.9 mm, duration - 265.3 @ 1mm 10.0 mm, duration - 268 @ 1mm
Jun Type 2 12.0 mm, duration - 266.6 @ 1mm 10.9 mm, duration - 265.3 @ 1mm
Jun Type 3 12.0 mm, duration - 265.3 @ 1mm 11.5 mm, duration - 265.3 @ 1mm
Spoon Sports 11.53 mm, duration - 256 @ 1mm 11.13 mm, duration - 245 @ 1mm
Skunk 2 stage1 11.58 mm, duration 252 @ 1mm 10.9 mm, duration 249 @ 1mm
Skunk2 stage 2 12.3 mm, duration 266 @ 1mm 11.8 mm, duration 262 @ 1mm
Skunk2 stage 3 12.8 mm, duration 273 @ 1mm 11.5 mm, duration 273 @ 1mm
Crower 63400 10.69 mm, duration - 244 @ 1mm 9.83 mm, duration - 231 @ 1mm
Crower 63401 11.38 mm, duration - 249 @ 1mm 10.54 mm, duration - 240 @ 1mm
Crower 63401T 11.81 mm, duration - 240 @ 1mm 11.30 mm, duration - 237 @ 1mm
Crower 63402 11.84 mm, duration - 258 @ 1mm 11.84 mm, duration - 251 @ 1mm
Crower 63402A 11.84 mm, duration - 246 @ 1mm 11.81 mm, duration - 239 @ 1mm
Crower 63403 12.04 mm, duration - 267 @ 1mm 11.84 mm, duration - 257 @ 1mm
Integra Type R 11.5 mm, duration - 240 @ 1mm 10.5 mm, duration - 235 @ 1mm
Civic Type R 11.5mm, duration - 243 @ 1mm 10.5 mm, duration - 235 @ 1mm
Old Mar 22, 2005 | 08:15 PM
VIS250P's Avatar
^^^ Thank you Thank you.. :
Old Mar 22, 2005 | 10:05 PM
rodimus's Avatar
Default Re: CAM poll :Blox VS buddyclub (py)
people say they won't run the bc4's on a near stock itr motor, yet i see some itr owners run toda c's on their near stock blocks.
Old Mar 23, 2005 | 10:04 AM
red civic standard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98 1162 &raquo;</TD></TR><TR><TD CLASS="quote">Blox B's eat up the BC 3+ after VTEC. I wouldn't go with the BC IV with that setup.
It should be noted that these dyno tests were on different days and the BC 3+ chart was with a JDM DC 4-1 header and the blox cams were with the Vision header.
Old Mar 23, 2005 | 12:04 PM
itr1244's Avatar
Default Re: CAM poll :Blox VS buddyclub (red civic standard)
so BC4's on stock bottom end with valvetrain upgraded is not recommanded?
with thin head gasket?
Old Mar 23, 2005 | 12:10 PM
jeremy.'s Avatar
BC4's would be too much for stock compression...BC3+'s should be fine with stock valvetrain
Old Mar 23, 2005 | 12:41 PM
ITRacer121's Avatar
I would go with the BC 3+ those cams were HOT! the low end torque was like being in Vtec all the time!
oh and Thanks for comments on my graph!
Old Mar 23, 2005 | 01:33 PM
ultimatehonda's Avatar
That dyno of the blox vs the bc3's is not a good comparasion. It says on the graph that weather temp was 20 degrees cooler with the blox test. That could make a difference in the dyno.
Casperh2b
Dec 1, 2013 11:05 PM
gs1gsr
17
Oct 3, 2008 02:58 AM
HCivic45
12
Feb 7, 2007 11:59 AM
turbohf
45
Jul 28, 2006 09:22 PM
red civic standard
Sep 28, 2004 01:51 PM
