Technical Question: Ignition timing of EG Civics; How is it done?
Old Mar 21, 2005 | 03:33 PM
TauMax's Avatar
Default Technical Question: Ignition timing of EG Civics; How is it done?
I did a quick search, but I didn't find what I was looking for.
Can anybody tell me if 5G civics have ECU controlled ignition timing?
I suspect that the ignition timing is purely governed by RPM and vacuum. This is mechanically fixed.
I know on newer cars, that are distributorless, the ECU controls the ignition timing.
However, I keep reading references about ignition tables in 5G civic ECUs.
What are they refering to? Do the ECU have some control over how much vacuum there mechanical distributor sees, therefore indirectly control ignition advance/retard?
Old Mar 21, 2005 | 06:04 PM
Imprezor's Avatar
Default Re: Technical Question: Ignition timing of EG Civics; How is it done? (TauMax)
The final ignition timing is given by the mechanical position of the distributor, vacuum, and a slight electronic adjustement performed by the ECU. Correct me if wrong.
Old Mar 21, 2005 | 06:09 PM
ARIZONA's Avatar
Default Re: Technical Question: Ignition timing of EG Civics; How is it done? (Imprezor)
ECU governs fuel and timing maps.
Old Mar 21, 2005 | 06:13 PM
eK9aT10pSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TauMax &raquo;</TD></TR><TR><TD CLASS="quote">I know on newer cars, that are distributorless, the ECU controls the ignition timing.</TD></TR></TABLE>
2001+ cars
Old Mar 21, 2005 | 07:42 PM
TauMax's Avatar
Ok good. You confirmed that that the ECU does have some ability to adjust timing.
Do you know how though?
Does the ECU indirectly control the ignition timing by altering how much vacuum the distributor sees?
Does anyone know?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Imprezor &raquo;</TD></TR><TR><TD CLASS="quote">The final ignition timing is given by the mechanical position of the distributor, vacuum, and a slight electronic adjustement performed by the ECU. Correct me if wrong.</TD></TR></TABLE>
JohnnyEF
Feb 10, 2010 06:09 PM
sleeperb16a
Nov 5, 2004 10:04 AM
the.hamburglar
Oct 14, 2004 11:37 AM
Daniel
Aug 22, 2003 07:05 PM
