what is this wire?
Old Mar 21, 2005 | 08:07 AM
drowzysleeper's Avatar
Default what is this wire?
i recently spun a bearing snd had to pull my motor, during the process i noticed a wire coming directly out of the block on the driver side. i forget where it went to but my altenater belt rubbed it almost in half was wondering if anyoner could tell me what it was?
Old Mar 21, 2005 | 08:15 AM
civic-4-ges's Avatar
Default Re: what is this wire? (drowzysleeper)
Out of you block towards the timing belt?? Possibly right out of the timing belt cover?
boostedcivicsir's Avatar
Mr. Badwrench
if it is a 96 and up car it is probably the CKF sensor.
Old Mar 21, 2005 | 08:26 AM
Default Re: what is this wire? (boostedcivicsir)
what is a ckf sensor? i dont have a clue my dad said it could have something to do with oil pressure?
Old Mar 21, 2005 | 08:34 AM
snatch's Avatar
CKF sensor is crankshaft fluctuation sensor.
I'm 99.9% sure, someone correct me though if it's not.
Can you get a pic of said wire?
edit: Foristell, MO eh? You're not too far from me.
Old Mar 21, 2005 | 08:59 AM
Default Re: what is this wire? (******)
that sounds important, is that expensive? it is coming right out of my timing belt cover.
Old Mar 21, 2005 | 09:16 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Probably the crank angle sensor. If this is an ODB1 car, no need to worry about it.
Old Mar 21, 2005 | 09:46 AM
Default Re: what is this wire? (JDM_Ej)
its a 98 so its obd2, do i have to worry?
Old Mar 21, 2005 | 09:47 AM
****** where r u from?
SingleCamMnstr
Jul 9, 2015 07:36 PM
Scotty_06
Jul 3, 2011 09:01 PM
keefe
Jun 15, 2008 12:32 PM
Jams_Civic
Apr 8, 2008 09:24 PM
EKB18BPR3
May 29, 2004 06:27 AM
