Integra Tein SS's Spring Rate
http://www.team-integra.net/fo...age=1
Tein S-Tech spring:
Rate: Front-335 Rear-274
Drop: Front- 2.5" Rear- 1.7"
Progressive
Tein S-Tech spring:
Progressive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpizzle »</TD></TR><TR><TD CLASS="quote">http://www.team-integra.net/fo...age=1
Tein S-Tech spring:
Progressive
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAV3RiCK478 »</TD></TR><TR><TD CLASS="quote">tein SS not s-tech
here you go.
http://tein.com/ssdamp.html </TD></TR></TABLE>
I appreciate it.
Tein S-Tech spring:
Progressive
Thanks
here you go.
I appreciate it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridej7 »</TD></TR><TR><TD CLASS="quote">ive got the tein ss's on my 91 integra and they ride good. ive also got tokico 5-ways on them which help out also....
I thought that they were a coilover kit
. Are you just talking about the springs?
</TD></TR></TABLE>I thought that they were a coilover kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridej7 »</TD></TR><TR><TD CLASS="quote">yea, ive got just the springs, not coilovers. </TD></TR></TABLE>
The reason I ask is because I'm going to do a B18C-R motor swap and I know I'll need stiffer springs (because of the added weight). I was thinking Integra rated Tein's S-Tech's would do the job. I mean, it's a hatchie so I figured I would be more than safe with those.
From: hittin corners so hard you can taste my rims..
just beacuse your putting in a swap, doesnt' mean your adding another 1000 LBS, and need stiffer springs.
the tien SS's are very conservative... i have them on my stock B18C1, and its a WONDERFULL ride... OEM struts, and SS's, and i can't complain at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A »</TD></TR><TR><TD CLASS="quote">just beacuse your putting in a swap, doesnt' mean your adding another 1000 LBS, and need stiffer springs.</TD></TR></TABLE>
So what you think, I should just raise the springs (Tein Basic Damper) to adjust to the weight of the motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_Fan »</TD></TR><TR><TD CLASS="quote">Anyone know the stiffness of stock Integra springs? I didn't see that in the TI article.</TD></TR></TABLE>
Courtesy of ac_attack on the TI thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Gen 3
Stock type R
F 246 linear
R 140-246 proggresive
stock other gen 3
F 212 linear
R 117 linear</TD></TR></TABLE>
Stock type R
F 246 linear
stock other gen 3
F 212 linear
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote">I have the teg rate ss on my del sol. No complaints here.</TD></TR></TABLE>
I appreciate it.
I appreciate it.
