whats the widest tyre that will fit a 7.5 inch wide wheel?!?
Old Mar 21, 2005 | 01:03 AM
djnikko's Avatar
Default whats the widest tyre that will fit a 7.5 inch wide wheel?!?
At the moment im running 205/40/R17's, im wondering if I can stretch a 215 or 225 on there?
Your help is most appreciated
Old Mar 21, 2005 | 07:40 AM
Mike_C's Avatar
easily.
Old Mar 22, 2005 | 12:11 AM
djnikko's Avatar
Default Re: (Mike C)
So I can put a 225/40/R17 on there no sweat? I wasnt sure how flexible these things are...
Old Mar 22, 2005 | 05:23 AM
Mike_C's Avatar
it'll fit on the wheel, yes, but you're getting it a pretty large diameter wheel/tire combo. it may rub.
Old Mar 24, 2005 | 11:43 AM
Green JDM-R's Avatar
The wheel will take up to a 245 tire.
Old Mar 24, 2005 | 11:54 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: whats the widest tyre that will fit a 7.5 inch wide wheel?!? (djnikko)
It can vary from one make/model tire to another. Look up the specs for the tire you're considering. You can find them on the Tire Rack website or the tire manufacturer's website. The specs show the range of approved rim widths for each size of that particular tire. That will answer your question.
Old Mar 24, 2005 | 11:55 AM
Mike_C's Avatar
Default Re: (Green JDM-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Green JDM-R &raquo;</TD></TR><TR><TD CLASS="quote">The wheel will take up to a 245 tire.</TD></TR></TABLE>
but the car probably won't, so that's a moot point.
Old Mar 24, 2005 | 01:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">but the car probably won't, so that's a moot point.</TD></TR></TABLE>
He never stated what kind of car it was going on. In case you didn't read the TITLE of the thread, he asked specifically what the widest tire he could put on the rim, NOT THE CAR.
Old Mar 24, 2005 | 01:11 PM
Mike_C's Avatar
if you looked in his sig, he has a crx.
Old Mar 24, 2005 | 01:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">if you looked in his sig, he has a crx.</TD></TR></TABLE>
As stated above, the question is pertaining to the widest tire usuable on that wheel NOT THE CAR!!!! I guess some people want to be right so bad....
Old Mar 24, 2005 | 03:13 PM
Mike_C's Avatar
i don't want to be right so badly, i am... that is why i first said:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">easily.</TD></TR></TABLE>
it doesn't hurt to cover all your bases though, so it should be noted that a 245 will not fit under his crx.
YipMan_Style
Feb 12, 2008 03:43 PM
boostjunkieee
Jan 14, 2007 11:23 AM
SJR
Dec 3, 2004 08:25 AM
garados
Jul 28, 2002 03:17 PM
Flux
Mar 5, 2002 07:19 PM
