I Dont Know Why My Check Engine Light Keeps Coming Up
I Have A B16A motor. Every once i a while when i drive my check engine light comes on. The times that it goes on is when im ballin' or when im driving slow about 40 with it on 5th gear. I asked around and found out that B16 doesnt have an EGR valve.
I need Help Bad, its irratating me. PLEASE HELP!.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kameleon23 »</TD></TR><TR><TD CLASS="quote">Find out what code it is throwing</TD></TR></TABLE>
Pull your carpeting down on the passenger side under the glovbox up against the wall. Look what its flashing and go online and just look it up. Easiest way I can think of.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMej1Civic »</TD></TR><TR><TD CLASS="quote">I Have A B16A motor. Every once i a while when i drive my check engine light comes on. The times that it goes on is when im ballin' or when im driving slow about 40 with it on 5th gear. I asked around and found out that B16 doesnt have an EGR valve.
What does an EGR valve have to do with your check engine light coming on? No code = no help.
</TD></TR></TABLE>What does an EGR valve have to do with your check engine light coming on? No code = no help.
its comes on and stays on intill i shut off the car then the it goes aways when i turn it back on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMej1Civic »</TD></TR><TR><TD CLASS="quote">its comes on and stays on intill i shut off the car then the it goes aways when i turn it back on.</TD></TR></TABLE>
that is because you are resetting the ecu, while the CEL is on, pull the code... and then look it up in the list at the top of this forum. If you don't know how to pull the code, check the link at the top of the forum.
here you go:
https://honda-tech.com/zerothread?id=1171263
here you go:
ratatunas
Apr 10, 2008 05:49 AM
scoobyjr56
Sep 26, 2006 06:47 AM
Teggin2
Feb 18, 2004 12:04 PM
