idle funny
Old Mar 20, 2005 | 07:23 PM
dosJDM's Avatar
Default idle funny
idle jumps from 1 to 2 grand...changed the iac valve any other suggestions?
Old Mar 20, 2005 | 07:30 PM
dosJDM's Avatar
Default Re: idle funny (dosJDM)
Old Mar 20, 2005 | 07:33 PM
Kamin's Avatar
please wait longer to bump your thread.
and its a vacuum leak most likley.
Old Mar 20, 2005 | 07:36 PM
dosJDM's Avatar
Default Re: idle funny (Kamin)
man im tired as hell and the wife is bugging me to go to bed so ...i appologize for the bump......
Old Mar 21, 2005 | 01:06 PM
dosJDM's Avatar
Old Mar 21, 2005 | 01:40 PM
EK k kay's Avatar
Check for vacuum leaks around the throttle body and intake manifold and where the manifold connects to the head.
Old Mar 21, 2005 | 01:46 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dosJDM &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
what?
did you even go look for vacuum leaks?
Old Mar 21, 2005 | 02:15 PM
joey1320's Avatar
check for the iac, fitv, any leaks and bleed the coolant.
i got the same problem and replaced the iac, fitv, and bled the coolant, now i'm in search of leaks... i'll get it done this weekend..
Old Mar 22, 2005 | 07:04 AM
dosJDM's Avatar
Default Re: idle funny (joey1320)
let you guys know this weekend...thanks for all the help though!!!!!! thumbs down was for how bad it sucks and how much work im doing and no time to work on it until the weekend
Old Mar 25, 2005 | 12:18 PM
dosJDM's Avatar
does anyone have a pic of the fitv? i want to know if what im taking apart is right....knowing me its not so any help would be awesome
Old Mar 25, 2005 | 01:01 PM
dosJDM's Avatar
bump
Old Mar 25, 2005 | 06:46 PM
dosJDM's Avatar
b
Old Mar 25, 2005 | 07:09 PM
Apocolipse269's Avatar
Default Re: (dosJDM)
the FITV is right below your TB, check the archive for info on it, but you should take the flat face off of it, and screw down the white center peice. Thats what caused the bouncing idle in my car. hope that helps
Old Mar 25, 2005 | 07:29 PM
dosJDM's Avatar
thats where i get lost...i looked for it and i don't understand where your talking about.....if someone has a pic of it from a motor or something....I looked under the tb and behind and in front....its two screws....i took off this plate behind the tb and inside was like a bronze piece and like a plastic washer or something so ..i put that back on and decided i was in the wrong place
Old Mar 25, 2005 | 09:12 PM
pumpsow's Avatar
i like to know too, anyone?
Old Mar 25, 2005 | 10:02 PM
https://honda-tech.com/zerothread?id=699787
thats a How To on fixing the FITV
It's Located Directly under the TB, with i believe 3 bolts holding it on (D series TB) It also has one coolant line going in and a vacuum line attached. It is not to be confused w/ the IACV which is on teh Back of the TB, behind the Intake Manifold (if you are standing direcly in front of your car) The FITV is DIRECTLY under the TB. I wish i had some pics but none (
Old Mar 27, 2005 | 09:14 AM
dosJDM's Avatar
thanks!
Old Mar 27, 2005 | 10:08 AM
93CX's Avatar
probe your tps wires
luv2boost
Jun 2, 2008 06:33 PM
duscar
Feb 25, 2008 02:24 PM
RiceBurninCX
Jan 24, 2008 02:02 PM
96hatch87
Aug 25, 2007 03:06 PM
h22831
Jul 18, 2005 06:36 PM
