TPS sensor CEL code yet voltage reads that its working fine.
Old Mar 20, 2005 | 06:02 PM
137's Avatar
137
Default TPS sensor CEL code yet voltage reads that its working fine.
WHAT THE ****!!!
Why would my throttle position sensor say its bad but if I check the voltage on it its working fine. And when I slowly open the throttle the voltage slowly moves up to 4.5 as im told it should. What the **** am I supposed to do now?
Old Mar 20, 2005 | 06:13 PM
Hybrid96EK's Avatar
Default Re: TPS sensor CEL code yet voltage reads that its working fine. (137)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 137 &raquo;</TD></TR><TR><TD CLASS="quote">WHAT THE ****!!!
Why would my throttle position sensor say its bad but if I check the voltage on it its working fine. And when I slowly open the throttle the voltage slowly moves up to 4.5 as im told it should. What the **** am I supposed to do now? </TD></TR></TABLE>
Thats fine, what is the voltage with the throttle fully closed?
Old Mar 20, 2005 | 06:23 PM
137's Avatar
137
Default Re: TPS sensor CEL code yet voltage reads that its working fine. (Hybrid93Eg)
.20 somthing..
Old Mar 20, 2005 | 06:27 PM
ABK's Avatar
ABK
open/short in signal wire
isn't fully closed supposed to be like .4-.5V I might be wrong though, don't spend time adjusting those too much.
Old Mar 20, 2005 | 06:42 PM
137's Avatar
137
Default Re: TPS sensor CEL code yet voltage reads that its working fine. (ABK)
no short trust me I searched on this all day.
Old Mar 20, 2005 | 06:55 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 137 &raquo;</TD></TR><TR><TD CLASS="quote">.20 somthing.. </TD></TR></TABLE>
And thus you have your problem. Closed should be .5 volts. You need to adjust the TPS.
Old Mar 21, 2005 | 08:31 AM
137's Avatar
137
how does one "adjust" the tps?
Old Mar 21, 2005 | 09:22 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 137 &raquo;</TD></TR><TR><TD CLASS="quote">how does one "adjust" the tps?</TD></TR></TABLE>
Simple. Remove the throttle body. Bust out a dremel with a cutting disc.. "Notch" the rivets similar to a flat headded screw. Insert a screwdriver and loosen it up. Plug in the TPS, back probe the center wire and turn the key on. Adjust it to .5 volts closed, tighten the screws up. You're done.
Old Apr 1, 2005 | 12:23 AM
137's Avatar
137
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Simple. Remove the throttle body. Bust out a dremel with a cutting disc.. "Notch" the rivets similar to a flat headded screw. Insert a screwdriver and loosen it up. Plug in the TPS, back probe the center wire and turn the key on. Adjust it to .5 volts closed, tighten the screws up. You're done.</TD></TR></TABLE>
I ended up having to replace the tps sensor the otherone indeed ended up being bad and I also had to shorten the harness clip and soder some wires due to shorts and crimps in the harness connection.
Cars running great now.
hotxcivic92
Jan 10, 2008 12:48 PM
k624ash
Sep 9, 2007 07:32 PM
T_bones
May 21, 2006 05:35 AM
88crxhfb16
Nov 15, 2005 12:22 PM
SuzukaBlueAP2
Oct 16, 2003 02:39 PM
