93 hatch b18c swap does my p28 ecu need to be chippet?
Old Mar 20, 2005 | 02:56 PM
ted's Avatar
ted
Default 93 hatch b18c swap does my p28 ecu need to be chippet?
i got my 93 hatch back from the shop they did a b18c swap and used a p28 ecu.. i want to know if this ecu needs to be chippet for this motor swap? bec i dont think they did.. is chipping needed? sorrry im slowly leaning thanks for any help
Old Mar 20, 2005 | 03:12 PM
ian.'s Avatar
Default Re: 93 hatch b18c swap does my p28 ecu need to be chippet? (ted)
no but alot of people do it
Old Mar 20, 2005 | 03:24 PM
ted's Avatar
ted
so my ecu is fine than? just the butterflys will not work with a p28 ecu right....whats the reson for chiping the p28 more hp or other things? ? Would u recommed i chip my ecu? thanks for your help
Old Mar 20, 2005 | 03:46 PM
nate_d's Avatar
Default Re: 93 hatch b18c swap does my p28 ecu need to be chippet? (IC33)
Basically the p28 is made to run a sohc vtec motor with 125 hp, you can run this ecu with your swap, but you wont get the most out of your 1.8, so its not necessary, but its definaltley recommended
Old Mar 20, 2005 | 04:16 PM
ted's Avatar
ted
allright thanks alot man.. Could any one recommed a Good chipping methed i should use on my b18c swap? with basic mods I/H/E may be some cams and other lil toys. thanks for the help
Old Mar 20, 2005 | 06:53 PM
dohcVTECeg2's Avatar
wtf is chippet??? do you mean chipped?
Old Mar 20, 2005 | 06:55 PM
Luserkid's Avatar
Default Re: 93 hatch b18c swap does my p28 ecu need to be chippet? (dohcVTECeg2)
Go back to the shop and tell those ******* to give you the correct ECU (p72)
Old Mar 21, 2005 | 09:26 AM
SleeperDC2_ZzZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IC33 &raquo;</TD></TR><TR><TD CLASS="quote">how much liters does a b16a have</TD></TR></TABLE>
1.6?
Old Mar 22, 2005 | 01:14 PM
acteg93's Avatar
its already vtec... just if u want it mapped differently or to match the b18c specs
JDMhoe1992
Dec 23, 2011 05:22 PM
[JDM]93_Eg6
Jun 19, 2009 08:37 AM
rainorshine81286
Oct 8, 2007 03:12 PM
obuhmyuh
May 6, 2007 05:33 AM
eg6hatch
Aug 7, 2003 04:29 PM
