00 civic si idle question
Old Mar 20, 2005 | 11:16 AM
bluesi00's Avatar
Default 00 civic si idle question
when i turn my civic on everything is fine, then i give it a little gas and when i comes back down the idle drops to about 3-4 hundred. and stays there for a while like it wants to turn off. what can i do to fix this? by the way i have a 255 walboro fuel pump and 9:1 84 mm bore je pistons. i used to have turbo on this and now that i took it off i cant get it to stay at a good idle. someone help me please.
Old Mar 20, 2005 | 12:36 PM
bluesi00's Avatar
Default Re: 00 civic si idle question (bluesi00)
Old Mar 20, 2005 | 01:30 PM
Junkie Si's Avatar
what ecu are you using on it right now ? ? ?
Old Mar 20, 2005 | 01:58 PM
bluesi00's Avatar
stock ecu
Old Mar 20, 2005 | 09:35 PM
bluesi00's Avatar
Default Re: (bluesi00)
Old Mar 21, 2005 | 09:04 AM
bluesi00's Avatar
Old Mar 21, 2005 | 10:27 AM
blue2ksi's Avatar
any alterations to the ecu or any piggyback systems?
Old Mar 21, 2005 | 10:41 AM
bluesi00's Avatar
none at all. i do have a 255 walbro fuel pump and 9:1 je pistons 84 mm bore
Old Mar 21, 2005 | 10:45 AM
teknoracing's Avatar
Why did you take the turbo off?
Old Mar 21, 2005 | 10:52 AM
bluesi00's Avatar
because im gonna trade the car in.
Old Mar 22, 2005 | 05:39 PM
Junkie Si's Avatar
well since u dropped the compression...do u think the stock ecu could be making your car act like that? ...just a few ideas...thats it
Old Mar 22, 2005 | 06:11 PM
red91sit's Avatar
Default Re: (marcosh)
could you try advancing the timing?
Old Mar 22, 2005 | 06:36 PM
bluesi00's Avatar
i advanced the timing. still does it. how do i clean out the iac?
Old Mar 22, 2005 | 06:43 PM
Junkie Si's Avatar
take the iacv off and spray the little screen with some carb cleaner...or just soak the valve part in some sea foam...hope that helps
Old Mar 22, 2005 | 06:53 PM
bluesi00's Avatar
ok, i'll do that tomorrow. thanks.
2000blksi
May 19, 2011 02:22 PM
bronxhazards
Aug 12, 2009 03:16 PM
Ruben19
Feb 2, 2006 10:33 PM
bluesi00
Mar 21, 2005 12:18 PM
CHOSEN1
Mar 1, 2003 08:19 AM
