00 civic si idle question
Old Mar 20, 2005 | 10:19 AM
bluesi00's Avatar
Default 00 civic si idle question
when i turn my civic on everything is fine, then i give it a little gas and when i comes back down the idle drops to about 3-4 hundred. and stays there for a while like it wants to turn off. what can i do to fix this? by the way i have a 255 walboro fuel pump and 9:1 84 mm bore je pistons. i used to have turbo on this and now that i took it off i cant get it to stay at a good idle. someone help me please.
Old Mar 20, 2005 | 10:38 AM
bluesi00's Avatar
someone help me . any suggestions are appreciated.
Old Mar 20, 2005 | 12:36 PM
bluesi00's Avatar
Default Re: (bluesi00)
Old Mar 20, 2005 | 09:37 PM
bluesi00's Avatar
Old Mar 21, 2005 | 09:02 AM
bluesi00's Avatar
ttt
Old Mar 21, 2005 | 09:18 AM
JDM00SI's Avatar
maybe check for vacum leaks.... i had a similar problem with my idle except it would go from 1k to 2k and go up and down......i went to autozone brought some little rubber tube type thing, covered where the air was coming in. now i idle perfect. is idle at 900 normal?
Old Mar 21, 2005 | 09:20 AM
bluesi00's Avatar
yea, i checked my vacuums and everything is good. i have a good idle its just when i give it gas and my rpms come back down they drop low and stay low at about 300
Old Mar 21, 2005 | 09:59 AM
Katman's Avatar
you can try loosening up your idle adjustment screw and adjust it accordingly...
Old Mar 21, 2005 | 10:05 AM
bluesi00's Avatar
is that on the bottom part of the throttle body or on the far side on the intake manifold?
Old Mar 21, 2005 | 10:12 AM
Katman's Avatar
its on the topside of the TB as seen here:
Old Mar 21, 2005 | 10:40 AM
bluesi00's Avatar
ok thanks. i'll go do that now.
Old Mar 21, 2005 | 12:18 PM
snatch's Avatar
When you adjust your idle with the idle adjustment screw, you can't just go turning it. You have to unplug the IACV after the car is fully warmed up and then adjust it. Once search comes back up, check around for it. Make sure you do it right. You can also try cleaning out the IACV, that can sometimes cause issues like your describing.
b20bFourDoorCivicLX
Honda CR-V & Element
Oct 10, 2013 06:35 PM
Tyrant_007
Mar 28, 2011 08:01 PM
Civicse
Feb 7, 2005 11:52 AM
97hb
Jan 24, 2003 11:12 AM
