Suspension & Brakes Theory, alignment, spring rates....
what camber kit for koni agx's w/ lowering springs
Old Mar 20, 2005 | 11:03 AM
thegoods217's Avatar
Default what camber kit for koni agx's w/ lowering springs
ya i need to get a camber kit for my 00si b/c of the toe wear on my front 2 tires. what kit should i go for? skunk2, onmi, ingall? or any other brand you recommend. also should i get new rear lca's? are megan any good or should i go for omnipower? any info would be appreciated!
Old Mar 20, 2005 | 11:04 AM
MattP's Avatar
Default Re: what camber kit for koni agx's w/ lowering springs (thegoods217)
If you have toe wear, why don't you just get the toe set correctly?
Old Mar 20, 2005 | 11:11 AM
Default Re: what camber kit for koni agx's w/ lowering springs (MattP)
i just got new tires and am going to get my car alligned on monday, but since its lowered a camber kit is in order. i am wondering what kit would be best
Old Mar 20, 2005 | 12:25 PM
Lo-Buck EF's Avatar
toe is factory adjustable. so you wouldnt need a camber kit to adjust toe. but i think you have the two confused. if you want to get a camber kit to fight camber wear, go for the skunk2 arms or the ingals.
Old Mar 22, 2005 | 07:08 PM
DLudist's Avatar
what exactly is toe wear? does it also affect the rear tires?
Old Mar 22, 2005 | 08:26 PM
DsITR's Avatar
Default Re: (DLudist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLudist &raquo;</TD></TR><TR><TD CLASS="quote">what exactly is toe wear? does it also affect the rear tires?</TD></TR></TABLE>
The front and rear have toe settings.
Here is toe
Also check this link, good reading
http://216.239.53.104/search?q...UTF-8
rainorshine81286
10
Dec 3, 2006 10:36 AM
nhiczx
Jul 10, 2006 12:03 PM
B18C5er
Suspension & Brakes
20
Nov 18, 2005 07:44 AM
eymnewdc4
Jul 17, 2005 12:36 PM
CivicSwapper
Dec 11, 2003 06:53 AM
