dented right passenger fender
now... should i attempt to push the thing out? i've done it to the bumper, but it was mickey/mouse. is there a certain method used? or just get a new 1 and paint it?
it all depends on the dent. it would be very useful for a picture of it. but most likely you just wannna replace the thing. they are not too expensive.
(ways to fix dent)
slide hammer and weld pins
hammer and dolly
etc.
(ways to fix dent)
hammer and dolly
etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 »</TD></TR><TR><TD CLASS="quote">now... should i attempt to push the thing out? i've done it to the bumper, but it was mickey/mouse. is there a certain method used? or just get a new 1 and paint it?</TD></TR></TABLE>
Don't push it out. It's metal and just won't push out. Don't take it out and start hammering the inside either, it'll crack the paint on the other side. If the dent is small go to an auto parts store and buy the dent puller that you see on tv. Believe it or not it actually works. My buddy just ran into the side of my garage last week and we pulled the dent out with one of those. But If the dent looks really bad then you're better off just getting a new fender.
drill a hole and pull it with a hook or something even depending on how accessible the dent is.. make sure you don't pull any part WITHIN the dent above the surface of the straight metal part... straighten it as well as you can...
you gotta sand it down, bondo it, primer it and then paint and clear coat it..
you can always get a new fender and paint it but i think it's a good way to learn how to fix smaller dents
the body shop didnt do a good job bending it bak together so my fender looks like it curves in towards the headlights...how can i bend that out to make it straighter??
teg racer 877
Paint and Body
15
Dec 17, 2007 12:55 PM
nofearmikeshere
Honda Civic (2006 - 2015)
Oct 23, 2007 03:37 PM
