Car missing under load....might be fuel....
Old Mar 19, 2005 | 11:08 PM
bennjamin@ozhonda.com's Avatar
Default Car missing under load....might be fuel....
hi guys...quick question.
My stock hodna civic , with a DOHC ZC stock - isnt performing too hot of recent.
Under normal acceleration , the car is fine ( slow throttle application )
But under mid to heavy acceleration thru all gears - the engine makes a audible faint "wobbling" noise under load ...and there is a lack of power indeed.
Wether this is misfing or what - my first option is to check appropiate fuel is getting thru.
I took off the 10mm top bolt to the fuel filter while OFF - and no fuel leaked out - and then i heard a faint " bom....bom....bom...." coming from the pipe . Air pressure is displacing something.
Shouldnt an amount of fuel leak out of the outlet regardless on/off ?
What are DIY ways to tell if the fuel filter is clogged ?
Thanks for a first step !
Old Mar 20, 2005 | 03:44 PM
Default Re: Car missing under load....might be fuel.... (bennjamin@ozhonda.com)
bump it up for what its good for...
DevontElan
Feb 14, 2008 03:16 PM
muggins
Oct 8, 2007 12:24 AM
JDMKid71
22
Mar 11, 2006 08:57 AM
ek_slut
Sep 23, 2005 02:00 PM
