Suspension & Brakes Theory, alignment, spring rates....
Wheel stud/ Hub Removal Help Please searched
Old Mar 19, 2005 | 07:14 PM
HCivExoo's Avatar
Default Wheel stud/ Hub Removal Help Please searched
Help !!! I need to get my hub off to replace two wheel studs and i can't get the hub off. I been using a slide hammer and it won't move, i used an axle puller ad pushed the axle out the back of the hub/ steering knuckle. I don't know what else to do. Any help would be greatly appreciated thanks.
And moderators if this in the wronf place movee it!!
also: 2000 Civic Ex Passenger side Front
thanks
Old Mar 19, 2005 | 07:37 PM
Lord Helmet's Avatar
Default Re: Wheel stud/ Hub Removal Help Please searched (HCivExoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCivExoo &raquo;</TD></TR><TR><TD CLASS="quote">Help !!! I need to get my hub off to replace two wheel studs and i can't get the hub off. I been using a slide hammer and it won't move, i used an axle puller ad pushed the axle out the back of the hub/ steering knuckle. I don't know what else to do. Any help would be greatly appreciated thanks.
thanks </TD></TR></TABLE>
this is all you need to pull the hub out: http://www.thetoolwarehouse.ne....html I've use this tool endless times with painless results.
the key to removing it is to kept the axle still in it slightly. remove the nut on the axle until it's flushed with the axle and using this tool press the hub out. simple done
BTW spraying down the hub(at where the spindle and hub meets) with wd-40 or any lube will help this process.
Old Mar 19, 2005 | 08:07 PM
HCivExoo's Avatar
Default Re: Wheel stud/ Hub Removal Help Please searched (sleeperciv)
Yeah i was using Kroil Oil, it is a pretty good penitrating oil. I used some heat and was able to get it off.
Yeah i used that axle/ hub puller and it pushed the axle out the back most of the way.
Thanks for your all your help, preciate it
Old Mar 19, 2005 | 08:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCivExoo &raquo;</TD></TR><TR><TD CLASS="quote">Yeah i was using Kroil Oil, it is a pretty good penitrating oil. I used some heat and was able to get it off.
Thanks for your all your help, preciate it</TD></TR></TABLE>
if you still kept the axle nut on the axle it would not move out of the hub, hence you have a backstop to use to pull the hub out.
Old Mar 20, 2005 | 04:27 AM
Adi Radoncic's Avatar
On Fire!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">
if you still kept the axle nut on the axle it would not move out of the hub, hence you have a backstop to use to pull the hub out. </TD></TR></TABLE>
No because the axle is nutted to the hub so it doesn't come out.
Old Mar 20, 2005 | 12:45 PM
Lo-Buck EF's Avatar
Default Re: Wheel stud/ Hub Removal Help Please searched (newgsr)
why not just get the dremel out. trim off some of the back of the broken studs and hammer them out. then "D" the new ones and slip them in.
Old Mar 20, 2005 | 01:22 PM
Dan GSR's Avatar
https://honda-tech.com/zerothread?id=720159
Old Mar 20, 2005 | 04:50 PM
Lo-Buck EF's Avatar
Default Re: Wheel stud/ Hub Removal Help Please searched (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=720159
yea, that how it *should* be done. but who has access to a press?
Old Mar 20, 2005 | 05:05 PM
Dan GSR's Avatar
Default Re: Wheel stud/ Hub Removal Help Please searched (Lo-Buck EF)
only crazy folk
Old Mar 20, 2005 | 06:39 PM
Lo-Buck EF's Avatar
very helpfull in my "my wheelberring is shot and my wheel is gonna fall off" emergancy
Old Mar 20, 2005 | 10:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr &raquo;</TD></TR><TR><TD CLASS="quote">
No because the axle is nutted to the hub so it doesn't come out.</TD></TR></TABLE>
You don't understand, if you leave the axle nut on it slightly with a few thread on it and press it out with that hub puller you will break the "lock" the hub has on the spindle. I've done this hundreds of times on a lot of different FWD cars with the same results.
Old Mar 20, 2005 | 10:50 PM
On Fire!
Ahhh damn man I guess you learn something new everyday! Thanks for the heads up! This might even save me money in the long run case i got some bearings n hubs i need to take out myself.
Old Mar 20, 2005 | 10:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr &raquo;</TD></TR><TR><TD CLASS="quote">Ahhh damn man I guess you learn something new everyday! Thanks for the heads up! This might even save me money in the long run case i got some bearings n hubs i need to take out myself.</TD></TR></TABLE>
Not a problem
Old Apr 7, 2005 | 10:00 AM
M15's Avatar
M15
What do you do if all o fyour studs are broken except for one and yo uneed to get the Hub off?
Old Apr 7, 2005 | 12:12 PM
rioninja's Avatar
Default Re: Wheel stud/ Hub Removal Help Please searched (M15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M15 &raquo;</TD></TR><TR><TD CLASS="quote">What do you do if all o fyour studs are broken except for one and yo uneed to get the Hub off?</TD></TR></TABLE>
You buy one of them harbor freight presses. Its actually not bad for the money, and DAMN handy
Old Apr 7, 2005 | 01:27 PM
FORCEDFEDTEG's Avatar
I used a gear puller to remove the hub. heres a link https://honda-tech.com/zerothread?id=495293 Then to press the bearing and hub back. I used a 1/2" threaded rod, two 1/2" nuts and two 4"x4" plates 1/4'" thick with a 1/2" hole drill out on center. Just sandwich the knuckle and hub with the plates run the rod threw the holes on the plate and tighten the nuts. Use a lot of oil and a torch will help. I've done all the bushings, wheel bearing and, wheel lug on my car with out a press.
Old Apr 9, 2005 | 09:02 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">only crazy folk
I've got that bad boy sitting in my garage right now
Old Apr 10, 2005 | 01:18 AM
Tyson's Avatar
You don't understand, if you leave the axle nut on it slightly with a few thread on it and press it out with that hub puller you will break the "lock" the hub has on the spindle. I've done this hundreds of times on a lot of different FWD cars with the same results. </TD></TR></TABLE>
im reading what youre saying, but i still dont understand. do you mean that youre stretching the threads on the axle nut in order to break loose the hub? so basically youre sacrificing the axle nut? how do you insure the axle threads dont stretch either?
Old Apr 10, 2005 | 05:21 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF &raquo;</TD></TR><TR><TD CLASS="quote">why not just get the dremel out. trim off some of the back of the broken studs and hammer them out. then "D" the new ones and slip them in.</TD></TR></TABLE>
that doesnt work on cars with 10" front brakes. It works on ef's, but on integras/ex/si's, it wont work because the spindle is too close to the back of the stud and the stud will not be able to slide out the back without hitting the spindle.
Old Apr 11, 2005 | 06:43 PM
Default Re: Wheel stud/ Hub Removal Help Please searched (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
im reading what youre saying, but i still dont understand. do you mean that youre stretching the threads on the axle nut in order to break loose the hub? so basically youre sacrificing the axle nut? how do you insure the axle threads dont stretch either? </TD></TR></TABLE>
You're reading it wrong. The hub is stuck on the spindle. I suggested the Original poster he press the hub out by using the axle nut as a "holder" to prevent the axle from slipping out of the spindle. That's it and no it will not damage the threads on the axle nut because I've done it countless times and checked the threads afterwords by screwing it back on the axle by hand without any issues.
xlusiveracer
Mar 15, 2006 01:25 PM
HCivExoo
Mar 19, 2005 09:05 PM
ITR-00-1457
Dec 14, 2004 02:38 PM
integ u
Apr 25, 2004 12:37 PM
