No tuning with header and intake?
Old Jan 24, 2002 | 12:46 PM
Blue Liquid's Avatar
New User
Default No tuning with header and intake?
Is tuning neccesary when installing a new header and a new intake? Or could things be modified greatly with an AFC? Let's say I bought a DC JDM header and AEM CAI, how would you tune without an AFC?
Old Jan 24, 2002 | 12:48 PM
TypeR0149's Avatar
Default Re: No tuning with header and intake? (Yellow R #01-0468)
you should really tune any part you put in your car to get full potential
Old Jan 24, 2002 | 12:50 PM
New User
Default Re: No tuning with header and intake? (Vegeta)
I don't know how to tune without buying an AFC and going to a shop that knows what they're doing. How does one tune without the AFC?
Old Jan 24, 2002 | 12:51 PM
Type Goch's Avatar
New User
Tuning isnt necesarry but it would be good to get more power out of your setup. If you want to tune without a VAFC i guess you can do some ignition tuning or some other things. About 18 degrees was it? Not quite sure, but HTH
[Modified by Type Goch, 2:04 PM 1/24/2002]
Old Jan 24, 2002 | 01:03 PM
Ex-ITR5874's Avatar
Default Re: No tuning with header and intake? (Type Goch)
If your aftermarket header has bigger collectors, you`d be fine to do some cam gear tuning... Everytime you change something at the intake or exhaust side you should do cam gear tuning.
Imagine your header/cat/exhaust is a hose you make wider now. You slow down the velocity... The exhaust cam is the tap...
Old Jan 24, 2002 | 01:04 PM
Stock-DC2's Avatar
New User
No much you can do with the fuel if you don't have a AFC. Maybe if you have a FPR, you can adjust the fuel pressure a bit. Without any tuning device, all you can do is adjust the ignition timing, change the plug, plug wire and oil. Beside that, there really isn't much you can do.
Old Jan 24, 2002 | 02:54 PM
New User
Default Re: No tuning with header and intake? (DC2-Rated)
Thanks everyone, I'm going to look into these suggestions.
Old Jan 24, 2002 | 02:59 PM
Mike D's Avatar
I agree also you shoudl tune any upgrades. If you dont get an vafc the you should look into a FPR and cm gears.
If you think about, you are spending about 650 at the least, so why not get your moneys worht for a few extra bucks on teh dyno.
good luck
Mike D
Old Jan 24, 2002 | 10:56 PM
AJ PwR's Avatar
VAFC is good but I will think of going for a Greddy E-Manage or Buddyclub Racing Spec ECU for $300-$400 range. The Greddy and the Buddyclub have WAY better tunability over VAFC plus you can adjust the acceleration pump for more throttle response
eddysmith2000
16
Oct 20, 2014 06:10 PM
BMo Tuning
53
Sep 11, 2009 09:37 PM
sexyvtec88
Nov 23, 2008 06:11 AM
IVAN93EG
May 15, 2006 05:27 PM
milton
Dec 19, 2003 12:46 AM
