engine reving up and down on its own
It doesn't matter if it's in the morning or in the afternoon when it's warm it does the same reving up and down for like a minute. And now my SRS light is on for about 5 seconds after starting the car. Could these be related? Also I am smoking alot in the morning. What should I look for? I have a 92 Accord LX.
Does this occur after the car had been sitting for a while... or the engine is cold? and could it be that the "smoke" is because its cool outside in the morning?
if so you have nothing to worry about. and that srs light is for about 3 seconds... its performing a test.. making sure the srs is working properly.
as far as the revving up and down, for a start you could check this out
-air pockets in cooling system
-iacv on intake mani. common problem with irratic idle.
i had a h22 engine with my stock ecu in my 97 accord, then i got a gsr ecu, that helped,,,,,but what really made the difference was the fuel pump regulater,,,,get that, it doesnt even do it anymore
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitalayon »</TD></TR><TR><TD CLASS="quote">It does it when the engine is cool. I am not sure if this is right. And yes the smoking is in the morning. It smells like burning oil.</TD></TR></TABLE>
usually cars smoke in the morning cuz overnight water condensies in the pipes...but if it smells like burning oil look closely at the smoke, if its a lil blueish, then yea ur burning oil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Intense2.2 »</TD></TR><TR><TD CLASS="quote">dude there is nothing wrong with your car... </TD></TR></TABLE>
if you dont have it fixed yet and need some ideas, this thread is where i had the same problem.....https://honda-tech.com/zerothread?id=1152061
bassrocker521
Feb 20, 2008 05:51 PM
zak88lx
Jun 5, 2007 01:33 PM
