Cant get car in gear while turned on??
Old Mar 18, 2005 | 09:24 PM
k20em2's Avatar
Default Cant get car in gear while turned on??
After i did my burnout at the track today, I tried to put it in 1st gear and couldn't shift it to 1st or any other gear. I just had the exedy hypersingle clutch installed just 3 weeks ago. I can put it in gear fine with the car turned off. I can put it in first turn the car on and it'll grab and the car starts moving. Any ideas on what the problem could be?Could it be the throwout bearing? Any help would be appreciated, thanks.
I'm planning on checking the clutch fluid level tomorrow.Along with the clutch master cylinder.
Old Mar 18, 2005 | 10:28 PM
Slow ass EF's Avatar
Default Re: Cant get car in gear while turned on?? (k20em2)
sounds like ur clutch isnt disengaging... are you hearing any weird noises
Old Mar 18, 2005 | 10:49 PM
SlowReaction's Avatar
Default Re: Cant get car in gear while turned on?? (LSVTECJay)
Its your presure plate. More then likely you bent the fingers on them. I've had it happen before.
Old Mar 18, 2005 | 11:13 PM
PrettyLude's Avatar
check for any visible leaks of brake fluid
Old Mar 19, 2005 | 06:18 AM
k20em2's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">check for any visible leaks of brake fluid</TD></TR></TABLE>
No, I havent seen any leaks. I checked the clutch fluid and it was black.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTECJay &raquo;</TD></TR><TR><TD CLASS="quote">sounds like ur clutch isnt disengaging... are you hearing any weird noises</TD></TR></TABLE>
I was hearing some weird noises at idle near the clutch/brake resvoir. Both fluid leves are good. Execpt the clutch reservoir has black fluid in it.
Any other sugestions? If I did bend a pressure plate, hopefully I can just buy the pressure plate and get that changed out instead of a whole new clutch.
Old Mar 19, 2005 | 07:40 AM
jdmcx's Avatar
Default Re: (k20em2)
you need to adjust the pedel
Old Mar 19, 2005 | 01:51 PM
k20em2's Avatar
Default Re: (jdmcx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcx &raquo;</TD></TR><TR><TD CLASS="quote">you need to adjust the pedel </TD></TR></TABLE>
Checked my pedal, nothing wrong with it.
Old Mar 19, 2005 | 03:13 PM
TurboEM1's Avatar
just curious did you break the clutch in? 3 weeks seems awfully short. They recomend about 900 miles of easy city driving.
Old Mar 19, 2005 | 04:53 PM
k20em2's Avatar
Default Re: (TurboEM1)
I drove about 400-500 miles, city driving.
jwshilli
Jul 14, 2009 03:02 PM
race200sx
Sep 21, 2008 04:48 PM
Luchini
Oct 16, 2005 11:15 AM
40oztoFreedom
Jun 3, 2004 11:40 AM
jteasy
Oct 30, 2001 07:12 PM
