Who can take the EGR out of my ecu?
Old Jan 24, 2002 | 11:21 AM
Mikey3000's Avatar
Default Who can take the EGR out of my ecu?
topic says it all.
Old Jan 24, 2002 | 01:35 PM
Greyout's Avatar
Default Re: Who can take the EGR out of my ecu? (Jonesy69)
lol
the only thing I can think of is that he is getting a CE light and wants to know how to get rid of it?
Old Jan 24, 2002 | 01:50 PM
Mikey3000's Avatar
lol not the EGR valve itself. i'm not going to run an EGR valve so don't i need something done to the ecu so i don't get a check engine light?
Old Jan 24, 2002 | 04:08 PM
DirtyLude's Avatar
Default Re: Who can take the EGR out of my ecu? (H22Turbo)
You mean a EGR lift code from having it unplugged, or a flow error from having it disconnected?
You have a 5th Gen? Then nobody can. You would need to move to a different ECU.
Old Jan 25, 2002 | 05:28 AM
Mikey3000's Avatar
Default Re: Who can take the EGR out of my ecu? (DirtyLude)
damn i dunno. it's a 95 H22A. the motor or ecu isn't in the car yet. i just heard that you get a code if you don't have your EGR hooked up and you can get it reprogrammed out of the ecu so you don't get a light.
Old Jan 25, 2002 | 06:48 AM
2point6's Avatar
In my case I made an aluminum gasket without the holes in it between the EGR valve and the manifold. NO dealing with the emmissions people that way.
Old Jan 25, 2002 | 06:56 AM
WICKED2's Avatar
New User
the only way to take out egr is to change your ecu to si ecu or gsr thats what i did on mine. i used a topfuel intake manifold direct from japan and its running fine on my car
Old Jan 25, 2002 | 10:05 AM
Mikey3000's Avatar
Default Re: Who can take the EGR out of my ecu? (2point6)
i'm using the Hondata gasket kit so there's no hole in mine for EGR either. So will I have a CE light when i start it up?
Old Jan 26, 2002 | 06:20 AM
nicksweetlude's Avatar
just a suggestion, you might try sending your computer to Jet performance and tell them to upgrade it and to see if they can take out the egr code. tell them its for a race only car if they ask.
efjones9
16
Jun 10, 2009 08:33 AM
zenon8890
Mar 12, 2009 02:21 PM
z6CRXSi
Jun 7, 2005 12:41 PM
frostt3ch
10
Jun 22, 2003 11:09 AM
