Engine break in? Tuning?
Old Mar 18, 2005 | 06:24 AM
Pikachu's Avatar
Default Engine break in? Tuning?
Ok, my motor is currently being built. It consists of a GE sleeved open deck H22, 9 to 1 compression pistons and pauter rods. Everything else is stock. This is going to be dropped into my 92 CX hatch. I spoke to a tuner about breaking it in on a dyno and he told me that I didn't need to tow it to him. He told me since the only thing that's different on this motor is the compression, the stock P13 should run it fine. Now my question is, Is it safe to drive on the honda ecu to the tuner(1.5hrs away)? Could I break it in with a stock ecu on? I'm taking it to my tuner so he can tune my AEM EMS. This is completely NA. Thanks in advance guys.
Old Mar 18, 2005 | 08:06 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Engine break in? Tuning? (Pikachu)
If everything is stock, you're using a stock ECU, you should be fine. It would be nice if you have a wideband o2 handy though, just to make sure your AFR is good. The only thing I would do is make sure that your timing is set to stock.
Old Mar 18, 2005 | 11:48 AM
Honda Hick's Avatar
Whats the stock compression on a H22? I don't know if the stock ECU will be able to correctly compensate for the change in compression, I guess that's really what you have to find out. You don't want to be running too lean or rich on a newly built motor where things aren't broken in yet.
Old Mar 18, 2005 | 03:20 PM
PrettyLude's Avatar
just set the right fuel pressure and it will be ok
Old Mar 18, 2005 | 05:59 PM
drdisco69's Avatar
Default Re: (PrettyLude)
Yeah, 9:1 isn't detonation prone like 12.5:1. Pull a little timing out, add a couple lbs of fuel pressure and drive it.
Old Mar 18, 2005 | 06:15 PM
Pikachu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">just set the right fuel pressure and it will be ok</TD></TR></TABLE>
How much fuel pressure should i set it to?
Old Mar 18, 2005 | 08:41 PM
Kendall's Avatar
Default Re: (Pikachu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pikachu &raquo;</TD></TR><TR><TD CLASS="quote">How much fuel pressure should i set it to?</TD></TR></TABLE>
Try around 45 psi and see how it runs.
Old Mar 18, 2005 | 11:16 PM
PrettyLude's Avatar
i have pretty much the same setup as you, try around 45 like kendall said and adjust accordingly, mines is set at 42
G2IntegraGS
Engine Management and Tuning
May 2, 2009 05:51 PM
954bballer091
Sep 13, 2008 07:38 PM
Pikachu
Mar 18, 2005 03:13 PM
93H22ACX
Apr 2, 2004 02:40 PM
Black R
Mar 1, 2002 08:37 AM
