need help were does this connect to- vtec not engaging.
Old Mar 18, 2005 | 04:01 AM
1993acuraintgralsvtec's Avatar
Default need help were does this connect to- vtec not engaging.
im looking into my engine bay, and to the right off of the gsr intake manifold theres a little pod with a vaccum hose on the top. it looked really lose so i pulled it and wa-la it wasnt connected to anything. where does this connect? and could this be the reason the vtec doesnt engage?
ne help would be great.... ill try to get a picture
Old Mar 18, 2005 | 08:09 AM
Default Re: need help were does this connect to- vtec not engaging. (1993acuraintgralsvtec)
bump i need help
Old Mar 18, 2005 | 08:24 AM
JimBlake's Avatar
IAB maybe? If so, that's not VTEC. Some people think it is, since it usually makes more noise when it opens the secondaries.
There should be a vacuum reservoir under the intake manifold, & a solenoid valve to close/open the secondaries.
Old Mar 18, 2005 | 08:28 AM
Default Re: need help were does this connect to- vtec not engaging. (JimBlake)
dang i was hoping that was my problem since im getting great low end tourque and the engine just dies in vtec
Old Mar 18, 2005 | 08:54 AM
JimBlake's Avatar
If the hose is simply disconnected, the secondaries will be open. So your low end should suffer.
If the hose is disconnected but the secondaries are forced shut by wiring the little crank or whatever, then your top end should suffer.
Or maybe you're looking at something completely different. Pictures??
Old Mar 18, 2005 | 09:24 AM
alright ill get some pics once i find my damn digital camera
Old Mar 18, 2005 | 10:13 AM
the manifolds a 95 gsr
Old Mar 18, 2005 | 11:45 AM
dang it wheres my digi cam
Old Mar 18, 2005 | 12:53 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993acuraintgralsvtec &raquo;</TD></TR><TR><TD CLASS="quote">the manifolds a 95 gsr</TD></TR></TABLE>
The vacuum tank is #10, the IAB control solenoid is #9.
Old Mar 18, 2005 | 12:58 PM
its not #9 its the on the other side that #9 hose connects 2
Old Mar 18, 2005 | 01:09 PM
thanks for the diagram
Old Mar 18, 2005 | 01:41 PM
Looks like the hose broke off the IAB with it
Old Mar 18, 2005 | 02:33 PM
so should i get an aftermarket intake manifold or just get a new IAB valve
Old Mar 18, 2005 | 02:57 PM
Old Mar 18, 2005 | 06:58 PM
ne ideas
Old Mar 21, 2005 | 04:31 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993acuraintgralsvtec &raquo;</TD></TR><TR><TD CLASS="quote">so should i get an aftermarket intake manifold or just get a new IAB valve</TD></TR></TABLE>I'd just get a new IAB solenoid valve. But if you're really looking for an excuse to get a new manifold...
pizzamanprelude
Dec 17, 2006 08:39 AM
JDM H22
Apr 6, 2005 09:39 PM
phateless
Oct 16, 2004 06:37 PM
redhatchb18
10
Jul 25, 2004 07:24 PM
JdmFront619
Dec 23, 2003 10:48 PM
