itb's installed , sticky throttle (how to fix?)
Old Mar 18, 2005 | 03:27 AM
zz10xx's Avatar
Default itb's installed , sticky throttle (how to fix?)
hi all,
i installed my twm itbs; on k20a and the throttle is sticky as ****, its not funny driving it on the street, im just wondering anyone knows how to fix this problem?'
thanks
Old Mar 18, 2005 | 04:03 AM
JDMlyfestyle's Avatar
Does the throttle plates stick open or is it just really stiff?
Old Mar 18, 2005 | 04:17 AM
zz10xx's Avatar
reall ******* stiff, its too hard to control the throttle...
Old Mar 18, 2005 | 04:18 AM
zz10xx's Avatar
the throttle is actually stiffer than my Ogura single plate clucth,,,,,,
Old Mar 19, 2005 | 01:43 AM
zz10xx's Avatar
bump
Old Mar 19, 2005 | 09:59 AM
danimal's Avatar
Default Re: (zz10xx)
do you mean throttle sticking at the foot pedal, or throttle sticking directly at the itb's, when opened by hand, under the hood?
Old Mar 20, 2005 | 11:24 PM
zz10xx's Avatar
stiking on the throttle ....
Old Mar 22, 2005 | 03:31 PM
danimal's Avatar
i have seen throttle shafts get, like, twisted or bent slightly, and it caused a serious drag on the linkage... you got the itb's used, not new? were they binding up before they went on the car?
it sounds like you might need to start disconnecting linkage parts until you find out exactly what is binding, try to isolate something... i'd start out where it hooks up to the accelerator cable.
Old Mar 22, 2005 | 04:55 PM
92TypeR's Avatar
FSAE
Default Re: (danimal)
Before you start taking things apart, spray a bunch of microlubricant like WD-40 all over the throttle brackets and lines.
Old Mar 22, 2005 | 06:14 PM
Kendall's Avatar
It's possible that one of the throttle bodies has a warped shaft. As mentioned above, try to isolate the problem as best as you can. WD-40 will help, but it's a better idea to just go ahead and find the problem so that you can start working on a solution.
Old Mar 22, 2005 | 08:31 PM
zz10xx's Avatar
i bought the itbs brand new..
i will try the wd40
thanks!
Old Mar 22, 2005 | 09:49 PM
SMSP's Avatar
Default Re: itb's installed , sticky throttle (zz10xx)
Stronger return spring or a set of Jenveys.
Old Mar 22, 2005 | 11:21 PM
SuperTwinz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zz10xx &raquo;</TD></TR><TR><TD CLASS="quote">i bought the itbs brand new..
i will try the wd40
thanks!</TD></TR></TABLE>Dirt build up...
myep3isbroken
Jun 20, 2018 08:48 AM
Nameless Warrior
Feb 1, 2007 08:58 AM
philosofy1
Jan 10, 2007 07:46 PM
monkalotamus
Nov 15, 2006 06:31 PM
LSVTEC 91 Civic
15
Oct 28, 2005 06:16 PM
