pr3 chip acting weird????
Old Mar 17, 2005 | 06:47 PM
turbo boost's Avatar
Default pr3 chip acting weird????
hey i got a pr3 ecu on my lsvtec and none of the vtec wires r run yet...i got 3 chips a mugen...spoon...and a toda chip...the mugen 1 runs like **** and the other 2 the ...the red led on the ecu stays on steady....wtf??? and only revs to 3500...both the spoon and toda chip does this...whats wrong???is it cuz i dont have the vtec wires hooked up yet or what...?????????????????????
Old Mar 17, 2005 | 07:19 PM
Default Re: pr3 chip acting weird???? (snowbunny)
anybody know??? is it the chip s bad or is it in limp mode were i dont have the other wires hooked up?? the red led stays on steady...no flashin...just stays on...wtf????
Old Mar 17, 2005 | 08:54 PM
Redline130's Avatar
Where did you get the chips from? Who installed the eprom socket onto the board?
I would definitely finish your wiring however.
Old Mar 17, 2005 | 10:34 PM
drdisco69's Avatar
A steady red light mean an internal problem in the ecu. It sounds like the chips you have are bad. The 3500 rpm rev limiter is the ecu in limp mode, running off the backup maps. It means it's really pissed. I really wouldn't run some unknown chips in there, it's a good way to break something. Put the stock chip back in, finish the wiring and get it tuned the right way.
Old Mar 18, 2005 | 05:14 AM
Default Re: pr3 chip acting weird???? (drdisco69)
the chips r from hyper duct tunning....the mugen chip runs good...but the toda and spoon chip r in limp mode...must be bad chips....
Old Mar 18, 2005 | 02:01 PM
Old Mar 18, 2005 | 02:51 PM
Malgerus's Avatar
Are you putting the chips in the right way? If you are, and 1 of the 3 chips work, then the 2 that are bad likely have a bad bin (program) or are defective. Finish your wiring too. I never understood why people don't finish their wiring before screwing with stuff. I see you're located in Canada. I can burn 29C256 chips for the PR3, so if you're in the vancouver area I can maybe help you out.
Old Mar 18, 2005 | 03:21 PM
drdisco69's Avatar
Default Re: pr3 chip acting weird???? (Mr. S)
I have a bunch of .bins for all kinds of ecus as well. If you need something I can send it your way.
Old Mar 18, 2005 | 07:27 PM
kool...how can i get in contact with u...u got msn???
apexrift
Engine Management and Tuning
Oct 22, 2009 07:29 AM
siregcivic
Aug 20, 2005 02:39 AM
crxh22project
22
Feb 14, 2005 05:19 PM
iGoneRacing_GSR
Oct 31, 2003 03:20 AM
