bent shifter cables on 89' 2.0Si
Old Mar 17, 2005 | 06:14 PM
mugen92acintls's Avatar
Default bent shifter cables on 89' 2.0Si
I think I have a bent shift cable. I just replaced the motor and had to replace a heater hose and I noticed from then on 3rd gear will grind on the up-shift and down-shift. The most I noticed was the shifter cable was SLIGHTLY bent because I ran the heater hose UNDER the cables by accident. I know what I did wrong, I just need to know if a bent shift cable will cause the gears to clash. It seems logical to me because 3rd gear is the loosest point on the cable. If its bent, then the cable can not retracted all the way causing the shifter to bind up almost like when you miss a gear with rod shifters and grind because of the position it was angled. What do you guys think?
lancemah
10
Aug 14, 2013 05:46 PM
Mishako129
Sep 6, 2012 03:14 PM
1stgenboost
Honda Civic (2001 - 2005)
Mar 3, 2009 03:10 PM
H22A4Me
Mar 12, 2006 02:16 PM
