squeeky clutch pedal?? 94 GSR
I just noticed this today, everytime(almost) i push in the clutch pedal it's squeeks. It's not loud but quiet(you have to turn music off to hear it). what would this mean?? any help would be appreciated thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PLAGUEDDB7 »</TD></TR><TR><TD CLASS="quote">get a lil grease and lube it up..worked on my teg
Try that, if that dont work, check your slave & master cylinders.
</TD></TR></TABLE>Try that, if that dont work, check your slave & master cylinders.
pull back you dust boot onteh slave cylinder and squirt some non rubber eatin lube in there.
your best bet though is to have a friend push the pedal in why'll you find the noise. if its the slave cylinder, follow instructions above. if it is the pedal area, you might be due for a new master cylinder or hydraulic clutch system bleed.
FuNkDrSpOt
Oct 10, 2006 09:48 PM
