b16a rev limit
Old Mar 17, 2005 | 10:39 AM
b16a27's Avatar
Default b16a rev limit
i have a jdm b16a and it hits rev limit at like 7900 should i rasie it to make more power or is just not worth it because i heared of people making power all the way up to 8200 on them by the way how do i change my rev limter
Old Mar 17, 2005 | 12:01 PM
2000 MRP SI's Avatar
Default Re: b16a rev limit (b16a27)
Well you could get a chipped ecu to set a higher rev limit and some other goodies come with chipping ecus. Like launch staul, no speed limiter, full throttle shifting etc. What ecu are you running? becuause when I had my B16a in it didnt hit rev limit until 8500!!
Old Mar 17, 2005 | 01:00 PM
jdmsijdm's Avatar
are you sure its not just your tach? you should be able to rev a little higher than that. I bet your tach is off a little. Where does your vtec kick in?
Old Mar 17, 2005 | 01:10 PM
ce's Avatar
ce
stock rev limit is 8200..Think your tach is a bit off man
Old Mar 17, 2005 | 07:41 PM
jdmsijdm's Avatar
its not ALWAYS 8200. there are many variations with the p30 and pr3 ecu's. Some have higher xovers and fuel cuts than others.
Old Mar 17, 2005 | 09:28 PM
b16a27's Avatar
Default Re: (jdmsijdm)
p30 ecu nad i have a vfac and it also says 7900 so how will i be able to fix that
Old Mar 17, 2005 | 10:03 PM
EG6R's Avatar
Default Re: (b16a27)
Theres noting wrong with it. When i had a stock p30, my vafc says 7,900RPM also. Get a cheap chip if youre bothered by it.
Old Mar 17, 2005 | 11:08 PM
jdmsijdm's Avatar
cant you adjust your rev limit with your vafc? you must have a very old PR3 ecu
Old Mar 18, 2005 | 12:27 AM
EG6R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsijdm &raquo;</TD></TR><TR><TD CLASS="quote">cant you adjust your rev limit with your vafc? you must have a very old PR3 ecu</TD></TR></TABLE>
No, its just a Vtec, Air & Fuel Controller. I dont know, the ecu came with a G2 B16 92 i got.
Drsexiestboy
22
Sep 20, 2011 12:20 PM
znoj
Nov 5, 2010 01:14 AM
JDM EJ2
27
Jan 15, 2008 07:27 PM
b16a27
Mar 17, 2005 12:06 PM
skylinecivic
May 13, 2002 01:49 PM
