Help :: Starting a newly installed Engine.
Old Mar 17, 2005 | 10:34 AM
oxSLEEPERxo's Avatar
Default Help :: Starting a newly installed Engine.
I just installed a new z6 in my hatchback and having problems starting it up. Anyone have any tips going about this? Some detailed directions would be great. I did a search but there wasn't much detailed information.
Things I've checked:
- the spark plug wire sparks
- hoses
- fuses
- wiring
Any help will be greatly appreciated
Old Mar 17, 2005 | 10:36 AM
e jay one's Avatar
Default Re: Help :: Starting a newly installed Engine. (oxSLEEPERxo)
did you check for fuel maybe you forgot to plug something in?
Old Mar 17, 2005 | 10:38 AM
IHateJDM's Avatar
does the engine smell like fuel after you try to start it? (ie, are the injectors spraying?) Is your fuel pump kicking on? are you sure your timing is correct?
92-LS-Civic's Avatar
need more information, what is it doing when you try to start it?
Old Mar 17, 2005 | 10:39 AM
b204dr's Avatar
how far have you gotten it
do you have fuel
do you have spark
etc- need more information -
no cranking some thing must be miswired- cranking but not turning over- fuel or ignition most likly
Old Mar 17, 2005 | 11:08 AM
Default Re: (b204dr)
The engine is cranking, but it won't turn over. It does smell like fuel. As far as timing goes, this engine was removed from a running civic 3-4 months ago. It started right up back then, but it has just been sitting for the past 3-4 months. As for the plugs, everything is plugged in. I checked for spark by putting the spark plug wire next to a bolt and yes it sparked.
Old Mar 17, 2005 | 11:15 AM
IHateJDM's Avatar
Default Re: (oxSLEEPERxo)
plug wires in the correct order? what does it sound like?
Old Mar 17, 2005 | 11:47 AM
Default Re: (93delslo)
The spark plug wires are right. As far as ground, how many are there? One on the valve cover, tranny, and to the battery. those are the one ones i know of or can think of
Old Mar 17, 2005 | 12:48 PM
Anyone have any more ideas? Post it here or IM me on aim "oxsleeperxo" Your help will be greatly appreciated.
I mis-used the word turning over in my previous post. The engine is turning over, but it's not starting. It seems like it wants to start but just wont.
Old Mar 17, 2005 | 01:10 PM
esohsee's Avatar
you should check your timing... fuel filter... uhhhhhh... trying pumping the gas pedal while starting... haha that worked for my friends 4runner after it was sitting for months... i'd do the pumping thing last though...
Old Mar 17, 2005 | 01:16 PM
Jmunk's Avatar
I would start with the basics of making sure it has fuel and spark and go from there.
Old Mar 17, 2005 | 01:21 PM
Default Re: (Jmunk)
i know for sure it has sparks...as for fuel, i'm 80% sure
Old Mar 17, 2005 | 03:05 PM
need help asap
Old Mar 17, 2005 | 03:30 PM
2lua's Avatar
what about the ground near the thermostat?
Old Mar 17, 2005 | 03:52 PM
Default Re: (2lua)
The ground near the thermostat looks fine. I took it off and sanded it to make sure there's a good connection. Thanks though. Any more suggestions
Old Mar 17, 2005 | 04:02 PM
2lua's Avatar
what about your timing? are they correct?
Old Mar 17, 2005 | 08:01 PM
Default Re: (2lua)
i would pull the plugs, check see if they smell like gas, Is there any kind of putter, or anything, even if you have the spark plugs wrong, you should get like a back fire or something. is it throwing any codes? give us the whole story. from start to finish. then we'll help somemore.
Old Mar 17, 2005 | 08:03 PM
Default Re: (zdowell17)
https://honda-tech.com/zerothread?id=1182951
Josh Jennings
Oct 30, 2016 03:35 PM
Domnificent
Jul 24, 2010 01:48 PM
oxSLEEPERxo
Mar 18, 2005 11:23 AM
oxSLEEPERxo
Mar 18, 2005 10:14 AM
speedjunkeez
Jun 21, 2001 10:38 AM
