Oil pressure low in my GSR
Old Jan 24, 2002 | 06:07 AM
speedymon's Avatar
Default Oil pressure low in my GSR
I recently installed an oil pressure gauge in my 96 GSR. After the car runs for a while and has reached normal operating temps, the oil pressure will dip down around 11-12 psi. Is this normal? I heard the lowest should be 15. Is this true?
Old Jan 24, 2002 | 08:59 AM
jabroni95gsr's Avatar
Default Re: Oil pressure low in my GSR (speedymon)
did you check your oil level?
Old Jan 24, 2002 | 09:03 AM
speedymon's Avatar
Default Re: Oil pressure low in my GSR (jabroni95gsr)
Yes my oil level is up to par. But it still idles at that low psi level.
Old Jan 24, 2002 | 09:09 AM
JL 74's Avatar
maybe something is wrong with your gauge?
Old Jan 24, 2002 | 09:30 AM
HX_Guy's Avatar
Default Re: Oil pressure low in my GSR (jl74)
What is the pressure at 3000 rpms?
Old Jan 24, 2002 | 09:42 AM
speedymon's Avatar
Default Re: Oil pressure low in my GSR (HX_Guy)
Don't remember exactly but it's high i think. Ummm....55 maybe 60...
Old Jan 24, 2002 | 09:43 AM
HX_Guy's Avatar
I think your ok...
Spec is minimum of 10 PSI @ idle and 50 PSI @ 3000 RPMs
Old Jan 24, 2002 | 10:16 AM
speedymon's Avatar
Hey HX guy why don't you email me and let me know your set up? what do you have a B18C or a LS/VTEC? raydesouza@sprintpcs.com If you feel comfortable leaving your number maybe we can chat. I'm interested in making 190-200 whp.
Old Jan 24, 2002 | 10:18 AM
HX_Guy's Avatar
I have a B20VTEC, 12:1 compression, ITR cams, stock B16 head
Old Jan 24, 2002 | 10:50 AM
WOTTEG's Avatar
That's where my oil pressure was at Idle (when I had tha gauge installed).
Sounds like you are OK!
Old Jan 24, 2002 | 02:09 PM
Erik_Pb_Foot's Avatar
New User
Default Re: Oil pressure low in my GSR (WOTTEG)
I wish I had a gauge... i wouldn't have 12 melted valves, 3 spun bearings, and a lot of other serious problems right now.
Old Jan 24, 2002 | 04:44 PM
hybrider's Avatar
Default Re: Oil pressure low in my GSR (Pb_Foot)
indeed
sounds normal and good!
Old Jan 25, 2002 | 03:27 AM
speedymon's Avatar
Default Re: Oil pressure low in my GSR (hybrider93)
Actually i looked at it today and it was more like 70psi at 3k rpm. But thanks anyways. Gotta fix the leak in my oil pan, conveniently located over my header. Great
ProjectBB6
Sep 16, 2009 02:18 PM
88da3
Nov 21, 2005 10:31 AM
Harassing Herbs
Mar 16, 2004 05:09 PM
USDM 4G VTEC
Sep 3, 2003 08:26 PM
DuNkiN
Feb 22, 2002 05:50 AM
