98 gsr ?'s
On the 98 integra gsr, does the engine harness go through the firewall and plug to the ecu like the 99-00 civic SI or does it stop at the shock towers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7k rdlne »</TD></TR><TR><TD CLASS="quote">wires stop at the shock tower on 96 integras as well </TD></TR></TABLE>
yep I have a 96 and they stop at the shock tower.They all are at the shock towers 94 through 2001.You would need a full engine harness for a 94 or 95 they were obdI 96 up are obdII.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeper96 »</TD></TR><TR><TD CLASS="quote">
yep I have a 96 and they stop at the shock tower.They all are at the shock towers 94 through 2001.You would need a full engine harness for a 94 or 95 they were obdI 96 up are obdII.</TD></TR></TABLE>
so would a 94,95 obd1 harness plug into the obd2 plug on my shock tower ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI »</TD></TR><TR><TD CLASS="quote">
I don't think so,you would have to get a engine harness and a cabin harness to with a obdI ecu.
i already have the obd1 ecu, and an obd2 - 1 harness.
i need a new engine wiring harness since mines chopped.
so ill need a 94-95 cabin/engine harness?
all the wires that i have are useless then for my application?
btw thanks for the replies.
You could use the obdII engine harness,then you could get a piggy back to plug into the obdII harness inside the car and then to the obdI ecu.What year is your car and motor.This method will work only if you have a obdII motor then you could run the obdI ecu with the piggy back.
it should...pretty much any harness that would normally come with a b16....maybe even any b series obd1 harness....but if u have a b16 ecu then get b16 harness, or teg
