98 gsr in 96 hatch vacuum issue
i just recently swapped a 98 gsr into my 96 hb. i'm using my stock harness and i believe i wired everything correctly. now the thing is that my IACV is broken and i need to get a new one. i started my car yesterday and the engine rev'd up all the way to redline.. i was thinking a vacuum leak but i checked all hoses and there seems to be no leak. the only thing i'm thinking is that it could be the broken iacv. could this be the problem?
Re: 98 gsr in 96 hatch vacuum issue (eknorcal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eknorcal »</TD></TR><TR><TD CLASS="quote">i just recently swapped a 98 gsr into my 96 hb. i'm using my stock harness and i believe i wired everything correctly. now the thing is that my IACV is broken and i need to get a new one. i started my car yesterday and the engine rev'd up all the way to redline.. i was thinking a vacuum leak but i checked all hoses and there seems to be no leak. the only thing i'm thinking is that it could be the broken iacv. could this be the problem? </TD></TR></TABLE>
up
up
nobody knows??? bump!
its not a vacumme leak i can tell you that much.....your iacv motor probably i faulty i had a simular problem on my b18,
Re: 98 gsr in 96 hatch vacuum issue (wrenchmonkey12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrenchmonkey12 »</TD></TR><TR><TD CLASS="quote">its not a vacumme leak i can tell you that much.....your iacv motor probably i faulty i had a simular problem on my b18,</TD></TR></TABLE>
well it wasn't the iacv. it wouldn't make the car redline. just a few bolts on the IM that was loose.. thanks
Re: (drachir)
I had a very simmilar problem recently...
https://honda-tech.com/zerothread?id=1796847
turned out to be related to the carbon canister being from a GSR, and the hoses being from a civic Si (different sizes)
I dunno, maybe check that?
Re: (drachir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drachir »</TD></TR><TR><TD CLASS="quote">Almost sounds like your TPS wires are crossed. It happened when I swapped my CRX.</TD></TR></TABLE>
no.. as i stated above, the intake manifold wasn't on tight. it was loose and i tightened it and runs like a champ. thanks
Re: (Nate047)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nate047 »</TD></TR><TR><TD CLASS="quote">I had a very simmilar problem recently...
I dunno, maybe check that? </TD></TR></TABLE>
ohhh no its not that. i've already solved my problem before checking back on HT. but anyways, it's really weird cuz i'm not getting a CEL for the carbon canister. i'm running all 98 gsr parts in my 96 cx hb. the sensor for the carbon canister isn't hooked up and still not throwing a CEL. hahaha i'm in luck!
