ls/vtec ???'s (i searched)
hello fellow all mota heads. i have a question i am runnig a ls vtec with stock b18b bottom end with arp rod studs and ACL bearings and fully stock head, i have a b16 bottom end and was wondering if i took the pistons out and put them in my ls vtec how much more powerfull will me lil VX be. i know the compression ratio is like 11.5:1. so where does that put me in HP and TQ gains over my stock setup??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punkracer »</TD></TR><TR><TD CLASS="quote">ya 12.0:1 is alot.....i wanta run 93 maybe even 91 just to be safe.......but the qustion is how much gain over stock hp and tq figures.???</TD></TR></TABLE>
Not sure about an approximate HP gain, I'm running CTRs and a milled head with my setup.. probably around 12.3, I run on 93 pump with stock timing.
You definatley don't want LS pistons, you'll have around 9.3-9.5:1 compression with LS pistons.
ya thats what i have right now, (ls pistions) what head r u using i have b16 with stock cams and was wondering if theres any valve to pistion clearance problems? if i went to a toda spec b cams (witch i might be getting) would i just take in consideration for the lift on the cam. would i need the relief cut more? i know Honda Tunner did a B20/vtec and they used CTR cams, they said that they had to cut the rerliefs...if the relief was cut would that raise or lower my compression??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">You definatley want those B16 pistons in there. The CR is about 11.2 with PR3 (B16A) Pistons, and around 12.0:1 with PCT (CTR) pistons.</TD></TR></TABLE>If your using PCT pistons in an Ls/vtec your compression should be much higher than 12.0:1. I dont think you will need to cut the valve reliefs to run those cams, but to make sure just clay your motor since it will be apart anyway.
[QUOTE= I dont think you will need to cut the valve reliefs to run those cams, but to make sure just clay your motor since it will be apart anyway.[/QUOTE]
good point
good point
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punkracer »</TD></TR><TR><TD CLASS="quote">camp1320.com for the bearings and forgot where on the arp rud bolts but only paryed 35.00 shiped</TD></TR></TABLE>
Wow, $35 a piece or the set?
M2nR
Jun 27, 2006 09:19 PM
the.hamburglar
20
Jan 24, 2006 03:15 PM
the.hamburglar
Dec 28, 2005 10:44 PM
